[PATCH] Intel Pro 10/100B/100+ Ethernet seems to work well.
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Mon Jul 18 15:42:38 UTC 2005
This patch has been committed.  Thanks for reporting that
it works.
--joel (who is back but only beginning to dig out)
Karel Gardas wrote:
> Hello,
> Intel Pro 10/100B/100+ Ethernet identified as
> ``PCI IDs: 0x8086 0x1229 0x8086 0x2205 0xC''
> in netdemo, seems to work well -- tested only in netdemo on IBM ThinkPad
> T22 with the builtin NIC. Attached patch marks this card as tested. The
> patch is against CVS trunk sources as of today.
> Cheers,
> Karel
> Karel Gardas                  kgardas at objectsecurity.com
> ObjectSecurity Ltd.           http://www.objectsecurity.com
> Index: ./c/src/libchip/network/if_fxp.c
> RCS file: /usr1/CVS/rtems/c/src/libchip/network/if_fxp.c,v
> retrieving revision 1.15
> diff -u -r1.15 if_fxp.c
> --- ./c/src/libchip/network/if_fxp.c	17 May 2005 15:15:07 -0000	1.15
> +++ ./c/src/libchip/network/if_fxp.c	14 Jul 2005 20:56:35 -0000
> @@ -195,7 +195,7 @@
>   * them.
>  static struct fxp_ident fxp_ident_table[] = {
> -    { 0x1229,		"Intel Pro 10/100B/100+ Ethernet", UNTESTED },
> +    { 0x1229,		"Intel Pro 10/100B/100+ Ethernet", 0 },
>      { 0x2449,		"Intel Pro/100 Ethernet", UNTESTED },
>      { 0x1209,		"Intel Embedded 10/100 Ethernet", 0 },
>      { 0x1029,		"Intel Pro/100 Ethernet", UNTESTED },
