netdemo
g_YaneV
g_yanev at bulpost.com
Fri Jul 29 16:23:55 UTC 2005
Hhello,
I have some problems with running netdemo. The bord is mcf5282 based and I use
uC5282 port.
The problem is that I can't telnet to the board. All other commands are
working perfect(s, u & t ).
On startup rtems prints:
fs1: Ethernet address: 00:80:7f:22:61:77
Destination Gateway/Mask/Hw Flags Refs Use Expire Interface
default 10.10.10.4 UGS 0 0 0 fs1
10.10.10.0 255.255.255.0 U 0 0 1 fs1
10.10.10.4 UHL 1 0 1 fs1
Create socket.
Create socket.
Bind socket.
Bind socket.
Listen.
Listen.
Accept.
Accept.
So there is no problem opening the sockets. When I try to telnet the following
packages are passing via the network:
#tethereal -i eth0
Capturing on eth0
0.000000 10.10.10.4 -> 10.10.10.11 TCP 43689 > 24742 [SYN] Seq=0 Ack=0
Win=5840 Len=0 MSS=1460 TSV=164222258 TSER=0 WS=0
0.000452 10.10.10.11 -> 10.10.10.4 TCP 24742 > 43689 [RST, ACK] Seq=0
Ack=0 Win=0 Len=0
Any suggestions what did I do wrong, or from where to start the debugging.
regards,
George
