bdbuf: Disk I/O buffering
Eugeny S. Mints
emints at ru.mvista.com
Mon Jul 4 11:29:05 UTC 2005
Hello Kevin,
Kirspel, Kevin {Engineering - Osmetech CCD} wrote:
> I have built an rtems 4.6.0 release and it has worked beautifully for 2
> years. I added compact flash support to my build by using the IDE
> interface in rtems. Every thing works great as long as I keep the
> compact flash card in the system. I wanted to add support to rtems so
> that I may remove and insert the compact flash card whenever I want. I
> now probe() the compact flash device to make sure it is in place before
> I perform any ata_ioctl() commands. If the device is not in place, I
> return -1 with errno = ENODEV. This causes the bdbuf_swapout_task()
> function to enter an indefinite loop because it keeps on trying to call
> the ata_ioctl() routine with no success.
> The following code is taken from the bdbuf_swapout_task() function in
> bdbuf.c:
> /* transfer_sema initialized when bd_buf inserted in the mod chain
> first time */
> result = dd->ioctl(dd->phys_dev->dev, BLKIO_REQUEST, &req);
> rtems_disk_release(dd);
> if (result == -1)
> bd_buf->status = RTEMS_IO_ERROR;
> bd_buf->error = errno;
> /* Release tasks waiting on syncing this buffer */
> _CORE_mutex_Flush(&bd_buf->transfer_sema, NULL,
> CORE_MUTEX_STATUS_SUCCESSFUL);
> else
> if (bd_buf->in_progress)
> rtems_interrupt_disable(level);
> _CORE_mutex_Seize(&bd_buf->transfer_sema, 0, TRUE, 0, level);
> I am not a disk buffering guru, but what can I do to the
> bdbuf_swapout_task() ( or other functions ) to make it process the error
> so that at the higher levels and error code is returned.
Apart from that there is a bug that you discovered, the higher levels
are aware about status/error of this low level I/O via bd_buf->status
and bd_buf->error fields which are filled either in "if (result == -1)"
branch above (the swapout task algo is: a higher level task is awaiting
for a buffer blocking on transfer sema; the buffer is removed from
swapout task's queue of buffers to process at Chain_Get() and at
transfer sema release time higher level task gets control on a buffer
back with bd_buf status and error fields set appropriately) or at
bdbuf_write_transfer_done() execution time.
The bug you discovered is the following:
at the time ioclt returns "-1 " bd_buf->modified field is set. But a bit
below at
if (bd_buf->use_count == 0)
if (bd_buf->modified)
Chain_Append(&bd_ctx.mod, &bd_buf->link);
rc = rtems_semaphore_release(bd_ctx.flush_sema);
else
Chain_Append(&bd_pool->lru, &bd_buf->link);
rc = rtems_semaphore_release(bd_pool->bufget_sema);
since bd_buf->modified is not re-set (at normal path this field is reset
at bdbuf_write_transfer_done() before this part of code execution) the
rtems_semaphore_release(bd_ctx.flush_sema) leads to the infinit cycling
in swapout task.
Please let us know whether the patch attached fixes your problem (at
least inifinit cycling).
> My current scenario is this:
> 1. I boot the system with the compact flash card in place.
> 2. After task initialization, my main task initializes the ide
> partitions, mounts the drive, opens a file, writes data to the file,
> closes the file, and unmounts the drive. This works great.
> 3. I then remove the compact flash and repeat the process.
> 4. During the mount process, the system hangs in bdbuf_swapout_task() do
> to the fact that the dd->ioctl() returns -1;
Based on your scenario I'm concerned about whether the bug in swapout
taks is the main issue.
My understanding is that the scenario with removed flash shoud end up in
mount() call (more exaclty in
msdos_initialize_support()->fat_init_volume_info()->rtems_disk_lookup()
(if you use fat fs ) since rtems_disk_lookup() should fail if there is
no actual disk) and has not to have any deal with swapout task at all.
Eugeny
> Kevin Kirspel
> Osmetech
> 235 Hembree Park Drive
> Roswell GA, 30076
> 770-510-4444 x568
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20050704/2c6c5e7e/attachment-0001.ksh>
