smc driver
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Mon Jul 4 18:05:54 UTC 2005
Hi Philippe,
since the linker complaints about the function name INCLUDING the
parameters, possibly you (or the linked code) are using the function
undeclared and/or with the wrong calling/return parameters?
wkr,
thomas.
Philippe Simons schrieb:
> Hi,
> i've been playing with a smc driver for the gp32 bsp, but I ran into a
> strage issue...
> I was able to sucessfully mount the smc with the fileio sample, read
> some files and browse with the shell.
> now I'm trying to build an app which mount the smc, like fileio does,
> but link fails with
> undefined reference to `rtems_ide_part_table_initialize(char*)'
> I've checked librtemscpu.a and there is an ide_part_table.o with the fct
> rtems_ide_part_table_initialize...
> btw, the same app was able to link with Untar_FromMemory() fct which is
> in librtemscpu.a too...
> here is my system.h
> /* configuration information */
> #include <bsp.h> /* for device driver prototypes */
> #include <smc.h>
> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> #define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
> #ifdef CONFIGURE_INIT
> rtems_driver_address_table Device_drivers[] =
> CONSOLE_DRIVER_TABLE_ENTRY
> ,CLOCK_DRIVER_TABLE_ENTRY
> ,SMC_DRIVER_TABLE_ENTRY
> #include <rtems/bdbuf.h>
> rtems_bdbuf_config rtems_bdbuf_configuration[] = {
> {512,128,NULL}
> int rtems_bdbuf_configuration_size =( sizeof(rtems_bdbuf_configuration)
> /sizeof(rtems_bdbuf_configuration[0]));
> #endif
> #define CONFIGURE_MAXIMUM_TASKS 20
> #define CONFIGURE_MAXIMUM_SEMAPHORES 20
> #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 20
> #define CONFIGURE_INIT_TASK_PRIORITY 10
> #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_PREEMPT
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20
> #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
> #define CONFIGURE_INIT_TASK_ENTRY_POINT main_task
> #define CONFIGURE_INIT_TASK_NAME rtems_build_name( 'A', 'W',
> '3', '2' )
> #define CONFIGURE_INIT_TASK_STACK_SIZE (20 * RTEMS_MINIMUM_STACK_SIZE)
> #define CONFIGURE_EXTRA_TASK_STACKS (20 * RTEMS_MINIMUM_STACK_SIZE)
> #include <rtems/confdefs.h>
> I dont know whats wrong...
> TIA
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at:
http://www.imd-systems.de/pgpkey_en.html
