bdbuf: Disk I/O buffering
Kirspel, Kevin {Engineering - Osmetech CCD}
kevin.kirspel at osmetech.com
Tue Jul 5 13:27:26 UTC 2005
The patch fixes the swapout() problem. As you mention earlier, I now
have other issues that I will have to work out. If anything is
relevant, I will update this thread.
Kevin Kirspel
Osmetech
235 Hembree Park Drive
Roswell GA, 30076
770-510-4444 x568
-----Original Message-----
From: Eugeny S. Mints [mailto:emints at ru.mvista.com]
Sent: Monday, July 04, 2005 7:38 AM
To: Eugeny S. Mints
Cc: Kirspel, Kevin {Engineering - Osmetech CCD}; rtems-users at rtems.com
Subject: Re: bdbuf: Disk I/O buffering
forgot to mention:
first, sorry for the patch format, second the patch is agains 4.6.0 and
the third I've never compiled/tested it.
Eugeny
Eugeny S. Mints wrote:
> Hello Kevin,
> Kirspel, Kevin {Engineering - Osmetech CCD} wrote:
>> I have built an rtems 4.6.0 release and it has worked beautifully for
2
>> years. I added compact flash support to my build by using the IDE
>> interface in rtems. Every thing works great as long as I keep the
>> compact flash card in the system. I wanted to add support to rtems so
>> that I may remove and insert the compact flash card whenever I want.
I
>> now probe() the compact flash device to make sure it is in place
before
>> I perform any ata_ioctl() commands. If the device is not in place, I
>> return -1 with errno = ENODEV. This causes the bdbuf_swapout_task()
>> function to enter an indefinite loop because it keeps on trying to
call
>> the ata_ioctl() routine with no success.
>> The following code is taken from the bdbuf_swapout_task() function in
>> bdbuf.c:
>> /* transfer_sema initialized when bd_buf inserted in the mod chain
>> first time */
>> result = dd->ioctl(dd->phys_dev->dev, BLKIO_REQUEST, &req);
>> rtems_disk_release(dd);
>> if (result == -1)
>> bd_buf->status = RTEMS_IO_ERROR;
>> bd_buf->error = errno;
>> /* Release tasks waiting on syncing this buffer */
>> _CORE_mutex_Flush(&bd_buf->transfer_sema, NULL,
>> CORE_MUTEX_STATUS_SUCCESSFUL);
>> else
>> if (bd_buf->in_progress)
>> rtems_interrupt_disable(level);
>> _CORE_mutex_Seize(&bd_buf->transfer_sema, 0, TRUE, 0, level);
>> I am not a disk buffering guru, but what can I do to the
>> bdbuf_swapout_task() ( or other functions ) to make it process the
error
>> so that at the higher levels and error code is returned.
> Apart from that there is a bug that you discovered, the higher levels
> are aware about status/error of this low level I/O via bd_buf->status
> and bd_buf->error fields which are filled either in "if (result ==
-1)"
> branch above (the swapout task algo is: a higher level task is
awaiting
> for a buffer blocking on transfer sema; the buffer is removed from
> swapout task's queue of buffers to process at Chain_Get() and at
> transfer sema release time higher level task gets control on a buffer
> back with bd_buf status and error fields set appropriately) or at
> bdbuf_write_transfer_done() execution time.
> The bug you discovered is the following:
> at the time ioclt returns "-1 " bd_buf->modified field is set. But a
bit
> below at
> if (bd_buf->use_count == 0)
> if (bd_buf->modified)
> Chain_Append(&bd_ctx.mod, &bd_buf->link);
> rc = rtems_semaphore_release(bd_ctx.flush_sema);
> else
> Chain_Append(&bd_pool->lru, &bd_buf->link);
> rc = rtems_semaphore_release(bd_pool->bufget_sema);
> since bd_buf->modified is not re-set (at normal path this field is
reset
> at bdbuf_write_transfer_done() before this part of code execution) the
> rtems_semaphore_release(bd_ctx.flush_sema) leads to the infinit
cycling
> in swapout task.
> Please let us know whether the patch attached fixes your problem (at
> least inifinit cycling).
>> My current scenario is this:
>> 1. I boot the system with the compact flash card in place.
>> 2. After task initialization, my main task initializes the ide
>> partitions, mounts the drive, opens a file, writes data to the file,
>> closes the file, and unmounts the drive. This works great.
>> 3. I then remove the compact flash and repeat the process.
>> 4. During the mount process, the system hangs in bdbuf_swapout_task()
do
>> to the fact that the dd->ioctl() returns -1;
> Based on your scenario I'm concerned about whether the bug in swapout
> taks is the main issue.
> My understanding is that the scenario with removed flash shoud end up
in
> mount() call (more exaclty in
msdos_initialize_support()->fat_init_volume_info()->rtems_disk_lookup()
> (if you use fat fs ) since rtems_disk_lookup() should fail if there is
> no actual disk) and has not to have any deal with swapout task at all.
> Eugeny
>> Kevin Kirspel
>> Osmetech 235 Hembree Park Drive
>> Roswell GA, 30076
>> 770-510-4444 x568
> --- bdbuf.old.c 2005-07-04 15:21:52.000000000 +0400
> +++ bdbuf.c 2005-07-04 15:23:28.000000000 +0400
> @@ -1545,7 +1545,7 @@
> * and release semaphore */
> - if (bd_buf->modified)
> + if ((bd_buf->status != RTEMS_IO_ERROR) &&
(bd_buf->modified))
