examples not working with CVS head (todays sources) on pc386 BSP.
Karel Gardas kgardas at objectsecurity.com
Thu Jul 14 10:38:44 UTC 2005
And third attempt: the same happen even with examples obtained from RTEMS
CVS.
Thanks,
Karel
On Thu, 14 Jul 2005, Karel Gardas wrote:
> Hello,
> short followup, the same happen for powerpc-rtems/psim platform/bsp too.
> I've downloaded those examples from 4.6.2 release:
> ftp://rtems.com:/pub/rtems/4.6.2
> Thanks,
> Karel
>> Hello,
>> I try to compile hello_world_c application as described on:
>> http://www.rtems.org/onlinedocs/releases/rtemsdocs-4.6.2/share/rtems/html/started/started00064.html
>> I've followed the doc and succesfully compiled i386-rtems toolchain and
>> also pc386 rtems BSP of todays' CVS head source tree (RTEMS 4.7). I've set
>> appropriate env. var:
>> silence:/tmp/rtems/examples-4.6.2/hello_world_c$ echo $RTEMS_MAKEFILE_PATH
>> /home/karel/usr/local/pc386-i386-rtems-bsp/i386-rtems/pc386/
>> but unfortunately simple `make' as describe in doc above does not work:
>> silence:/tmp/rtems/examples-4.6.2/hello_world_c$ make
>> i386-rtems-gcc --pipe
>> -B/home/karel/usr/local/pc386-i386-rtems-bsp/i386-rtems/pc386/lib/ -specs
>> bsp_specs -qrtems   -g -Wall  -O4 -g         -c   -o o-optimize/test.o
>> test.c
>> test.c:31:22: error: confdefs.h: No such file or directory
>> make: *** [o-optimize/test.o] Error 1
>> The toolchain is new gcc4.0.0/binutils2.16.1/newlib1.13 and all required
>> rtems patches applied.
>> Are there any new instruction needed for examples to be built with RTEMS
>> 4.7?
>> Thanks,
>> Karel
>> ObjectSecurity Ltd.           http://www.objectsecurity.com
