MVME5500 not working with RTEMS 4.7 (CVS)
Phillip Sorensen pas37 at cornell.edu
Tue Jul 26 12:55:04 UTC 2005
>> I am know having trouble running the ticker sample.  I have added  the
>> fix from PR#773 but this does not change things.
>> Has anyone successfully used RTEMS 4.7 with the MVME5500?  Any one
>> have suggestions on what to look at.
> I'm using it but haven't updated with CVS in a long while.  I'll try  to
> sync against CVS today.  What are you seeing?
> Peter
I was seeing what appeared to be no clock ticks at all.  After some
digging, I found that the initialization code for the clockIrqData
structure that sets up the clock ISR in the
c/src/lib/libbsp/powerpc/shared/clock/p_clock.c file was commented out
in CVS sometime in May or June.  After re-enabling the initialization of
this structure things worked.
Phil
