MVME5500 not working with RTEMS 4.7 (CVS)
    Phillip Sorensen
    pas37 at cornell.edu
    Wed Jul 27 20:09:41 UTC 2005
> Can you get this patch to Eric Norum so he can review and commit it?
> Thanks.
In the end I needed to change three files to get the MVME5500 board
working.  I have attached the patch from my tree.
1. c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c
I added the Cpu_table.exceptions_in_RAM = TRUE; before the
initialize_exceptions() call since the exception handler address routine
know uses it.
2. c/src/lib/libbsp/powerpc/shared/clock/p_clock.c
I removed the comments preventing the clockIrqData structure from being
initialized.
c/src/lib/lipcpu/powerpc/mpc6xx/clock/c_clock.c
Added the & to the assembly call in the clockIsq routine as shown in PR#773.
Phil Sorensen
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20050727/6ffe8a51/attachment-0001.ksh>
