MVME5500 not working with RTEMS 4.7 (CVS)
Eric Norum
norume at aps.anl.gov
Thu Jul 28 18:59:22 UTC 2005
After discussing this with Kate Feng I have committed these changes.
Thanks!
(Now if only I could get the MVME2100 BSP working again ......)
On Jul 27, 2005, at 3:09 PM, Phillip Sorensen wrote:
>> Can you get this patch to Eric Norum so he can review and commit it?
>> Thanks.
> In the end I needed to change three files to get the MVME5500 board
> working. I have attached the patch from my tree.
> 1. c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c
> I added the Cpu_table.exceptions_in_RAM = TRUE; before the
> initialize_exceptions() call since the exception handler address
> routine know uses it.
> 2. c/src/lib/libbsp/powerpc/shared/clock/p_clock.c
> I removed the comments preventing the clockIrqData structure from
> being initialized.
> c/src/lib/lipcpu/powerpc/mpc6xx/clock/c_clock.c
> Added the & to the assembly call in the clockIsq routine as shown
> in PR#773.
> Phil Sorensen
> Index: c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c
> RCS file: /usr1/CVS/rtems/c/src/lib/libbsp/powerpc/mvme5500/startup/
> bspstart.c,v
> retrieving revision 1.10
> diff -u -r1.10 bspstart.c
> --- c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c 4 May
> 2005 19:30:09 -0000 1.10
> +++ c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c 27 Jul
> 2005 19:35:18 -0000
> @@ -406,7 +406,9 @@
> * Initialize default raw exception hanlders. See vectors/
> vectors_init.c
> + Cpu_table.exceptions_in_RAM = TRUE;
> initialize_exceptions();
> * Init MMU block address translation to enable hardware
> * access
> Index: c/src/lib/libbsp/powerpc/shared/clock/p_clock.c
> RCS file: /usr1/CVS/rtems/c/src/lib/libbsp/powerpc/shared/clock/
> p_clock.c,v
> retrieving revision 1.7
> diff -u -r1.7 p_clock.c
> --- c/src/lib/libbsp/powerpc/shared/clock/p_clock.c 17 May 2005
> 15:06:22 -0000 1.7
> +++ c/src/lib/libbsp/powerpc/shared/clock/p_clock.c 27 Jul 2005
> 19:35:18 -0000
> @@ -18,15 +18,13 @@
> #include <bsp/irq.h>
> #include <libcpu/c_clock.h>
> -static rtems_irq_connect_data clockIrqData;
> - = {BSP_DECREMENTER,
> +static rtems_irq_connect_data clockIrqData = {BSP_DECREMENTER,
> clockIsr,
> NULL,
> (rtems_irq_enable)clockOn,
> (rtems_irq_disable)clockOff,
> (rtems_irq_is_enabled) clockIsOn};
> int BSP_disconnect_clock_handler (void)
> return BSP_remove_rtems_irq_handler (&clockIrqData);
> Index: c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c
> RCS file: /usr1/CVS/rtems/c/src/lib/libcpu/powerpc/mpc6xx/clock/
> c_clock.c,v
> retrieving revision 1.13
> diff -u -r1.13 c_clock.c
> --- c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c 15 Apr 2005
> 18:30:11 -0000 1.13
> +++ c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c 27 Jul 2005
> 19:35:20 -0000
> @@ -81,7 +81,7 @@
> * The driver has seen another tick.
> do {
> - asm volatile ("mfdec %0; add %0, %0, %1; mtdec %
> 0":"=r"(decr):"r"(Clock_Decrementer_value));
> + asm volatile ("mfdec %0; add %0, %0, %1; mtdec %
> 0":"=&r"(decr):"r"(Clock_Decrementer_value));
> Clock_driver_ticks += 1;
Eric Norum <norume at aps.anl.gov>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
