ColdFire CVS Build Error with 4.0.0
Pavel Pisa ppisa4lists at pikron.com
Wed Jun 1 23:25:39 UTC 2005
>>fails with a gcc error:
>>'_VBR' has an incomplete type'
>>The pertinent code from /cpukit/score/cpu/m68k/rtems/score/m68k.h is
>>shown below.  The asterisked line appears to be where the problem occurs.
>>#elif ( M68K_COLDFIRE_ARCH == 1 )
>>extern uint32_t                     _VBR[];
>>#define m68k_get_vbr( _vbr ) _vbr = _VBR
>>#define m68k_set_vbr( vbr ) \
>>  do { \
>>    asm volatile ( "movec   %0,%%vbr " : : "r" (vbr)); \
>>***    _VBR = (void *)vbr; \
>>  } while(0)
>>CVS indicates that _VBR was changed fairly recently from
>>void* _VBR;
>>to
>>uint32_t   _VBR[];
Hello Joel and others,
I do not know, if this is of some value, but recent
Linux-2.6 kernels use next macros
#define SET_VBR(x) \
        __asm__ __volatile__ (" movec %0,%/vbr" : : "r" (x));
#define GET_VBR(x) \
        __asm__ __volatile__ (" movec %/vbr, %0" : "=g" (x) : );
I use '%/' combination in one of my system-less projects
for ages and it works well. So may it be, that it is preffered
GAS coding.
But I see other fundamental problem, you are trying to
set address of static array or setup full contents of
such array with open length. So this has to fail.
This
uint32_t   _VBR;
_VBR = vbr;
or that
uint32_t   *_VBR;
_VBR = (uint32_t*)vbr;
or even this
#define m68k_set_vbr( vbr_ignored ) \
  do { \
    asm volatile ( "movec   %0,%%vbr " : : "r" (_VBR)); \
  } while(0)
/*in some .c file*/
uint32_t   _VBR[256];
Is corrects. It seems that it is similar conception change
of address to static array which has broken MX1 ARM setup
before some time.
Best wishes
                Pavel Pisa
