Critical Section: rtems_timer_fire_after, rtems_timer_server_fire_after
Andrew Sinclair
Andrew.Sinclair at elprotech.com
Wed Jun 1 23:43:30 UTC 2005
Hello there,
I believe I have encountered a critical section problem with
rtems_timer_fire_after and rtems_timer_server_fire_after. According to
previous discussions on the mailing list it is acceptable to call these
during interrupts. There is a case I have found where calling these will
cause issues. I am using release 4.6.2.
If a task or low priority interrupt modify the same timer as a high
priority interrupt, then corruption of the timer chain can occur.
For sake of simplicity, I have listed the general algorithm in RTEMS
below.
Consider a task/low priority interrupt calling rtems_timer_fire_after.
Inside the marked critical section, a high priority interrupt may occur
and insert the same timer into the chain without the task/lower priority
interrupt having knowledge. When the task/lower priority interrupt
resumes, it blindly modifies watchdog->state back to inactive, and
reinserts the timer. This usually results in the timer chain previous
and next pointers forming a loop, and ultimately locking up the device
when another timer must be inserted.
Task
\-->rtems_timer_fire_after
\-->Watchdog_Remove
\--> disable interrrupts
\--> remove timer if WATCHDOG_ACTIVE or stop if being
inserted
\--> watchdog->state=WATCHDOG_INACTIVE
\--> enable interrupts
[critical section start]
\-->Watchdog_Initialize
\-->Watchdog_Insert_ticks
\-->Watchdog_Insert
\-->watchdog->state=WATCHDOG_BEING_INSERTED
[critical section end]
\-->disable interrupts
\-->while in timer chain
\-->if at insert position exit
\-->flash interrupts
\-->check if timer has been touched
\-->insert timer
\-->enable interrupts
My solution to this problem is listed below involves modification to
rems_timer_fire_after, rtems_timer_fire_after, and Watchdog_Insert.
Before watchdog->state is modified, I check disable interrupts and check
if it has been modified. If it has been modified, then abort.
I have listed relevant sections of code I hacked at below. Testing so
far appears to have solved this issue. I see now that I probably should
return RTEMS_INTERNAL_ERROR on abort.
Can anyone see problems with the changes I have made?
Kind Regards
Andrew Sinclair
rtems_status_code rtems_timer_fire_after(
Objects_Id id,
rtems_interval ticks,
rtems_timer_service_routine_entry routine,
void *user_data
Timer_Control *the_timer;
Objects_Locations location;
ISR_Level level; /*AS: line modified*/
if ( ticks == 0 )
return RTEMS_INVALID_NUMBER;
if ( !routine )
return RTEMS_INVALID_ADDRESS;
the_timer = _Timer_Get( id, &location );
switch ( location ) {
case OBJECTS_REMOTE: /* should never return this */
return RTEMS_INTERNAL_ERROR;
case OBJECTS_ERROR:
return RTEMS_INVALID_ID;
case OBJECTS_LOCAL:
(void) _Watchdog_Remove( &the_timer->Ticker );
/*AS: start, perform inline initialisation with interrupts disabled,
abort if watchdog touched*/
_ISR_Disable( level );
if (the_timer->Ticker.state != WATCHDOG_INACTIVE)
goto timer_fire_after_abort_insert;
the_timer->the_class = TIMER_INTERVAL;
_Watchdog_Initialize( &the_timer->Ticker, routine, id, user_data
_ISR_Enable( level );
/*AS: end*/
_Watchdog_Insert_ticks( &the_timer->Ticker, ticks );
_Thread_Enable_dispatch();
return RTEMS_SUCCESSFUL;
return RTEMS_INTERNAL_ERROR; /* unreached - only to remove warnings
/*AS: start*/
timer_fire_after_abort_insert:
/*AS: end*/
rtems_status_code rtems_timer_server_fire_after(
Objects_Id id,
void *user_data
extern Chain_Control _Timer_Ticks_chain;
if ( !_Timer_Server )
return RTEMS_INCORRECT_STATE;
if ( !routine )
if ( ticks == 0 )
case OBJECTS_ERROR:
case OBJECTS_LOCAL:
goto timer_server_fire_after_abort_insert;
the_timer->the_class = TIMER_INTERVAL_ON_TASK;
the_timer->Ticker.initial = ticks;
/*AS: end*/
_Timer_Server_stop_ticks_timer();
_Timer_Server_process_ticks_chain();
_Watchdog_Insert( &_Timer_Ticks_chain, &the_timer->Ticker );
_Timer_Server_reset_ticks_timer();
/*AS: start*/
timer_server_fire_after_abort_insert:
/*AS: end*/
void _Watchdog_Insert(
Chain_Control *header,
Watchdog_Control *the_watchdog
ISR_Level level;
Watchdog_Control *after;
unsigned32 insert_isr_nest_level;
Watchdog_Interval delta_interval;
insert_isr_nest_level = _ISR_Nest_level;
/*AS: start , check if watchdog has been touched, and abort if
necessary*/
if (the_watchdog->state != WATCHDOG_INACTIVE)
goto abort_insert;
/*AS: end*/
the_watchdog->state = WATCHDOG_BEING_INSERTED;
_Watchdog_Sync_count++;
restart:
delta_interval = the_watchdog->initial;
* We CANT use _Watchdog_First() here, because a TICK interrupt
* could modify the chain during the _ISR_Flash() below. Hence,
* the header is pointing to volatile data. The _Watchdog_First()
* INLINE routine (but not the macro - note the subtle difference)
* casts away the 'volatile'...
* Also, this is only necessary because we call no other routine
* from this piece of code, hence the compiler thinks it's safe to
* cache *header!!
* Till Straumann, 7/2003 (gcc-3.2.2 -O4 on powerpc)
for ( after = (Watchdog_Control *) ((volatile Chain_Control
*)header)->first ;
after = _Watchdog_Next( after ) ) {
if ( delta_interval == 0 || !_Watchdog_Next( after ) )
break;
if ( delta_interval < after->delta_interval ) {
after->delta_interval -= delta_interval;
break;
delta_interval -= after->delta_interval;
* If you experience problems comment out the _ISR_Flash line.
* 3.2.0 was the first release with this critical section
redesigned.
* Under certain circumstances, the PREVIOUS critical section
algorithm
* used around this flash point allowed interrupts to execute
* which violated the design assumptions. The critical section
* mechanism used here WAS redesigned to address this.
_ISR_Flash( level );
if ( the_watchdog->state != WATCHDOG_BEING_INSERTED ) {
goto exit_insert;
if ( _Watchdog_Sync_level > insert_isr_nest_level ) {
_Watchdog_Sync_level = insert_isr_nest_level;
goto restart;
_Watchdog_Activate( the_watchdog );
the_watchdog->delta_interval = delta_interval;
_Chain_Insert_unprotected( after->Node.previous, &the_watchdog->Node
the_watchdog->start_time = _Watchdog_Ticks_since_boot;
exit_insert:
_Watchdog_Sync_count--;
abort_insert: /*AS: line modified*/
