CVS access
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Thu Jun 9 13:56:45 UTC 2005
emu at ecubics.com wrote:
>>From: Thomas.Doerfler at imd-systems.de
>>Hi,
>>maybe you should try
>>cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS
>>login
>>with uppercase CVS at the end?
> I actually did, it was only cut&paste for the email, but I tried again with UC, and it still doesn't work :(
> $ cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS login
> Logging in to :pserver:anoncvs at www.rtems.com:2401/usr1/CVS
> CVS password:
> cvs [login aborted]: connect to www.rtems.com(216.107.91.229):2401 failed: Connection timed out
I just tried this from outside OAR's domain and it worked.
You do know that there is no password and you just press return.
> cheers
