CVS checkout
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri Jun 10 17:37:50 UTC 2005
Paul Whitfield wrote:
> emu at ecubics.com wrote:
>> Is the CVS meant to be checked out on top of an "old" rtems-4.6.2 ?
>> There are few files missing in the CVS (configure, install.sh, ...)
> RTEMS uses autoconf and automake tools to generate some
> of the files. These are "generated" files and therefore
> not usually checked into version control.
> You will need to generate these files if you wish to
> build from CVS. To generate these you must have
> autoconf and automake installed... and the
> correct versions of them.
> To generate the files (assuming a valid installation
> of autoconf and automake( run the script config/bootstrap
> in the top director of the source tree.
Just two points -- the CVS tree should be checked out into a new
directory.  And RTEMS provides RPMs for the version of
autoconf/automake required.  You need to use them.  Make sure
/opt/rtems-XXX/bin is first in your path.
> Regards
> Paul
