CVS, configure bootstrap
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri Jun 10 17:40:20 UTC 2005
emu at ecubics.com wrote:
> Hi all, so just installed autocon & automake, checked out CVS, but it is still missing the "Makefile.in" file ...
> Is this OK ? Probably not, as it can't compile RTEMS after that :(
Did you install the RTEMS auto* RPMs and use them?
This is likely a wrong auto* version issue.  You have probably
also generated a lot of unnecessary files.
> ------------------ cut -------------------------------
> $ ./bootstrap
> ./c
> configure.ac: installing `../install-sh'
> configure.ac: installing `../missing'
> configure.ac:10: installing `../config.guess'
> configure.ac:10: installing `../config.sub'
> ./c/src/ada-tests
> ' is already registered with AC_CONFIG_FILES.
> autoconf/status.m4:848: AC_CONFIG_FILES is expanded from...
> configure.ac:80: the top level
> autom4te: /usr/bin/m4 failed with exit status: 1
> aclocal: autom4te failed with exit status: 1
> automake: autoconf failed with exit status: 1
> grep: Makefile.in: No such file or directory
> ./c/src
> configure.ac:267: the top level
> ./c/src/lib/libbsp/arm/armulator
> Makefile.am: installing `../../../../../../compile'
> Makefile.am: installing `../../../../../../depcomp'
> ./c/src/lib/libbsp/arm/csb336
> ./c/src/lib/libbsp/arm/csb337
> ./c/src/lib/libbsp/arm/edb7312
> ./c/src/lib/libbsp/arm/gp32
> ./c/src/lib/libbsp/bare
> ./c/src/lib/libbsp/c4x/c4xsim
> ./c/src/lib/libbsp/c4x/c4xsim/tools
> ./c/src/lib/libbsp/h8300
> ./c/src/lib/libbsp/h8300/h8sim
> ./c/src/lib/libbsp/i386
> ./c/src/lib/libbsp/i386/i386ex
> ./c/src/lib/libbsp/i386/pc386
> ./c/src/lib/libbsp/i386/pc386/tools
> ./c/src/lib/libbsp/i386/ts_386ex
> ./c/src/lib/libbsp/i386/ts_386ex/tools
> ./c/src/lib/libbsp/m68k
