RTEMS BSP for Diamond Systems Prometheus and/or Hercules?
Till Straumann strauman at slac.stanford.edu
Thu Jun 16 20:31:27 UTC 2005
I usually port freebsd drivers in 1-2 days. If there are no endian
issues it's even easier. It seems that the chip is supported
by freebsd if_sis.c
Till.
Joel Sherrill wrote:
> Kevin S. Martin wrote:
>> It is a PC. The one thing I'm wonder about is the network driver.
>> These boards have a National Semi DP83815/6 Ethernet chip. Does a
>> RTEMS driver exist for this chip?
> I don't think so unless the SONIC driver will work.  Someone may have
> one or can comment on the difficulty of porting a driver from *BSD.
>> Maybe that's the question I should have asked the forum.
>> -Kevin
>>>> Does a RTEMS BSP exist for the Diamond Systems Prometheus and/or
>>>> Hercules? These are PC/104 x86 boards.
>>> How is this different hardware-wise from a standard PC?  It should
>>> be able to use one of the pcx86 BSP variants.
>>>> Thanks!
