PowerPC: new_exceptions status
Nickolay Kolchin nbkolchin at gmail.com
Thu Jun 23 11:31:27 UTC 2005
Hello,
It looks like new_exceptions model in current RTEMS CVS tree is a stub
and don't work in reality. The problem is in _CPU_ISR_install_vector
definitions (/c/src/lib/libbsp/powerpc/new-exceptions/cpu.c)
void _CPU_ISR_install_vector(
  uint32_t    vector,
  proc_ptr    new_handler,
  proc_ptr   *old_handler
  BSP_panic("_CPU_ISR_install_vector called\n");
This mean that rtems_interrupt_catch function don't work and it is
used in ATA driver (/c/src/libchip/ide/ata.c).
Can somebody clarify what is current status of new_exceptions
interface in PowerPC and what should be used instead of
rtems_interrupt_catch?
Nickolay
