CVS checkout
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Fri Jun 10 17:38:56 UTC 2005
emu at ecubics.com wrote:
>>RTEMS uses autoconf and automake tools to generate
>>some
>>of the files. These are "generated" files and
>>therefore
>>not usually checked into version control.
>>You will need to generate these files if you wish
>>to
>>build from CVS. To generate these you must have
>>autoconf and automake installed... and the
>>correct versions of them.
> That was hopefully the information I was missing ..
>>To generate the files (assuming a valid
>>installation of autoconf and automake( run the script
>>config/bootstrap in the top director of the source tree.
> there is only a bootstrap scripts in the root of rtems ... ?
> (rtems/bootstrap), not rtems/config/bootstrap ...)
Right.. cd rtems and ./bootstrap
> cheers & thanks
joel at OARcorp.com On-Line Applications Research
