RTEMS BSP for Diamond Systems Prometheus and/or Hercules?
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Thu Jun 16 19:56:03 UTC 2005
Kevin S. Martin wrote:
> It is a PC. The one thing I'm wonder about is the network driver. These
> boards have a National Semi DP83815/6 Ethernet chip. Does a RTEMS driver
> exist for this chip?
I don't think so unless the SONIC driver will work.  Someone may have
one or can comment on the difficulty of porting a driver from *BSD.
> Maybe that's the question I should have asked the forum.
> -Kevin
>>> Does a RTEMS BSP exist for the Diamond Systems Prometheus and/or
>>> Hercules? These are PC/104 x86 boards.
>> How is this different hardware-wise from a standard PC?  It should
>> be able to use one of the pcx86 BSP variants.
>>> Thanks!
