PowerPC: new_exceptions status
leonp at plris.com leonp at plris.com
Thu Jun 23 11:52:19 UTC 2005
On Thursday, 23 בJune 2005 14:48, Nickolay Kolchin wrote:
> > > This mean that rtems_interrupt_catch function don't work and it is
> > > used in ATA driver (/c/src/libchip/ide/ata.c).
> > This function is not in use with new_exception.
> > > Can somebody clarify what is current status of new_exceptions
> > > interface in PowerPC and what should be used instead of
> > > rtems_interrupt_catch?
> > BSP_install_rtems_irq_handler(&icd)
> > See files irq.h, irg.c.
> Thank you.
> Does this mean that rtems_interrupt_catch is obsolete and shouldn't be
> used with other architectures too? Or this is PowerPC specific issue?
AFAIK, all ports which use the new_exception processing must use these new API
functions. But I have used only PPC.
Leon Pollak
