Multilib swamp
Ralf Corsepius ralf.corsepius at rtems.org
Wed Mar 2 14:02:14 UTC 2005
On Wed, 2005-03-02 at 06:36 -0600, Joel Sherrill  wrote:
> I know TIll and I are being non-committal here but the perfect decision
> varies based upon the code in question, when it is executed. and when it
> can vary.  Untested or untestable code is obviously bad.  Creating
> multilib variants is even worse.  Given that this is an initialization
> issue, I would lean to dynamic checking -- this code ends up under
> libbsp anyway.
You don't need dynamic checking, if the code "ends up under libbsp". You
can add the code to libcpu or to the bsp in both cases and add
appropriate defines to bspopts.h or to CFLAGS to conditionally enable
it.
If you feel you need to use the code under cpukit, add appropriate
definitions ("extern functions" -- API!) to cpukit and implement these
functions into libcpu or the BSP.
The rule of thumb is: You must not add defines to cpukit/score, unless
inevitable.
Ralf
