powerpc mvme5500 clock off by factor of 150
    Joel Sherrill <joel@OARcorp.com>
    joel.sherrill at OARcorp.com
    Mon Mar  7 18:18:39 UTC 2005
Kate Feng wrote:
> Peter Dufault wrote :
>>Kate Feng wrote:
>>>Anyway, I have a look at the code :
>>> status = rtems_task_wake_after( task_index * 5 * get_ticks_per_second()
>>>Thus the time it takes is subject to the value of task_index.
>  > >That is how he can get the factor of 5 seconds, right ?
>>If its off by 150, not by 5. But where is the time base and decrementer
> enabled?
>> The code to do that is in mpc6xx/mmu/mmuAsm.S in the call to
>>"L1_caches_enables", but the call to that is commented out in
> mvme5500/startup/bspstart.c.
>> I tried just setting the bit in bspstart.c at that point but it didn't
> help.
> Please note that the bug I mentioned is  not mvme5500 BSP related.
> I meant there is a bug in tests/samples/ticker/tasks.c.  It was written:
>     if ( time.second >= 35 ) {
>       puts( "*** END OF CLOCK TICK TEST ***" );
>       exit( 0 );
>     put_name( Task_name[ task_index ], FALSE );
>     print_time( " - rtems_clock_get - ", &time, "\n" );
> I  took out the task_id so that it will wake up  after 5 seconds
> for all  three tasks.  Now it works just as you expected - 5 seconds.
I don't understand what you think is broken in this test?
Does this BSP create any hidden/BSP specific tasks?  That can
mess this test up.
> task_index = 34
> Tes - rtems_clock_get - 09:00:00   12/31/1988
> task_index = 35
> task_index = 36
> t_ta - rtems_clock_get - 09:00:00   12/31/1988
> skd - rtems_clock_get - 09:00:00   12/31/1988
> Tes - rtems_clock_get - 09:00:05   12/31/1988
> t_ta - rtems_clock_get - 09:00:05   12/31/1988
> skd - rtems_clock_get - 09:00:05   12/31/1988
> Tes - rtems_clock_get - 09:00:10   12/31/1988
> t_ta - rtems_clock_get - 09:00:10   12/31/1988
> skd - rtems_clock_get - 09:00:10   12/31/1988
> Tes - rtems_clock_get - 09:00:15   12/31/1988
> t_ta - rtems_clock_get - 09:00:15   12/31/1988
> skd - rtems_clock_get - 09:00:15   12/31/1988
> Tes - rtems_clock_get - 09:00:20   12/31/1988
> t_ta - rtems_clock_get - 09:00:20   12/31/1988
> skd - rtems_clock_get - 09:00:20   12/31/1988
> Tes - rtems_clock_get - 09:00:25   12/31/1988
> t_ta - rtems_clock_get - 09:00:25   12/31/1988
> skd - rtems_clock_get - 09:00:25   12/31/1988
> Tes - rtems_clock_get - 09:00:30   12/31/1988
> t_ta - rtems_clock_get - 09:00:30   12/31/1988
> skd - rtems_clock_get - 09:00:30   12/31/1988
> Tes - rtems_clock_get - 09:00:35   12/31/1988
> t_ta - rtems_clock_get - 09:00:35   12/31/1988
> skd - rtems_clock_get - 09:00:35   12/31/1988
> P.S.  My E-mailer does not  work very well for now,
> at least for  the incoming mail.
> Kate
