Clock not running (was Re: RTEMS4.7 and its tool chain (Re: powerpc mvme5500 clock off by factor of 150))
Kate Feng feng1 at bnl.gov
Tue Mar 8 17:36:49 UTC 2005
Peter Dufault wrote:
> On Mar 8, 2005, at 12:16 PM, Kate Feng wrote:
> > I do not see this related to the  origianl subject "powerpc mvme5500
> > clock off by factor of 150" at all.   I  built the  source of
> > c/src/tests/samples/ticker.  It works as expected.
> > The colck on the MVME5500 BSP always works fine.
How did the binary  I sent you run on your  mvme5500 ?
If the clock is not running with the binary I sent you,
then you should contact Motorla for repair.
Cheers,
Kate
