Clock not running (was Re: RTEMS4.7 and its tool chain (Re: powerpc mvme5500 clock off by factor of 150))
Kate Feng feng1 at bnl.gov
Tue Mar 8 17:56:58 UTC 2005
Peter Dufault wrote:
> On Mar 8, 2005, at 12:36 PM, Kate Feng wrote:
> > How did the binary  I sent you run on your  mvme5500 ?
> > If the clock is not running with the binary I sent you,
> > then you should contact Motorla for repair.
> It worked fine with your binary.
> There is still an interrupt always firing on mine, though.  Can you
> decipher what that interrupt is from the output I posted before?
I  would like to help you.  Sadly, I  have my own job to
worry about.  I will post the updated source on the WEB
as soon as I have made sure the change on the PCI API
works fine with all  my  application hardware.
If you would like to make your life easier,
I would recommend you to stay on the same release
of RTEMS (4.6.0) , BSP and the toolchain as mine.
Cheers,
Kate
