RTEMS loopback test
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Thu Mar 10 18:04:10 UTC 2005
Mike Bertosh wrote:
> Hi all,
> I am trying to get the loopback test to work on my Avnet MCF5282 eval board. I run
> the test and here is the output that it gives me:
> "Network" initializing!
> "Network" initialized!
> Try running client with no server present.
> Should fail with `connection refused'.
> Connect to server.
> Can't connect to server: Connection refused
> Client closing connection.
> Start server.
> Try running client with server present.
> Connect to server.
> Client task terminating.
> Using gdb I was able to figure out that the program halts in the
> internal_error_occurred function. I know that my clock tick is working and I am using
> polled i/o for my console driver. Does anybody have any ideas on why the internal
> error occurs? I'd appreciate any help. Thanks for your time.
Do a "bt" for backtrace and see where the error came from.
Without knowing much, I would guess that a resource ran out
and that it is probably file descriptors or Classic Semaphores
(for mutexes).
> Mike Bertosh
> Motion Control Systems, Inc.
> New River, Va
> 540.731.0540
