Cygwin Documentation
Camilo Alejandro Arboleda camilo.arboleda at spymac.com
Mon Mar 14 17:27:31 UTC 2005
You are missing the compiler (i386-rtems-gcc, i386-rtems-g++).
Check this:
Did your build/installation of gcc succeed?
Did you used the same --prefix for binutils an gcc?
Brian Rose escribió:
> The directory where my i386-rtems-as, i386-rtems-c++filt, etc are in
> the path. Do I need to link one to cc? OR is it enough to have the
> exe's in the path?
> Note: I do not see a i386-rtems-cc.
> This is what I have...
> i386-rtems-addr2line
> i386-rtems-ar
> i386-rtems-as
> i386-rtems-c++filt
> i386-rtems-ld
> i386-rtems-nm
> i386-rtems-objcopy
> i386-rtems-objdump
> i386-rtems-ranlib
> i386-rtems-readelf
> i386-rtems-size
> i386-rtems-strings
> i386-rtems-strip
> Is there anything missing?
Algo mas sobre Camilo?
http://camiloaa.spymac.net
http://camiloaa.blogspot.com
