Cygwin Documentation
Jay Monkman jtm-list-rtems at smoothsmoothie.com
Mon Mar 14 18:32:07 UTC 2005
On Mon, Mar 14, 2005 at 11:11:18AM -0500, Brian Rose wrote:
> This is what I have...
> i386-rtems-addr2line
> i386-rtems-ar
> i386-rtems-as
> i386-rtems-c++filt
> i386-rtems-ld
> i386-rtems-nm
> i386-rtems-objcopy
> i386-rtems-objdump
> i386-rtems-ranlib
> i386-rtems-readelf
> i386-rtems-size
> i386-rtems-strings
> i386-rtems-strip
> Is there anything missing?
Yes. You don't have i386-rtems-gcc. Did you install the compiler and
library? The filename would be something like
	 rtems-4.6-i386-rtems-gcc-gcc3.2newlib1.11.0-4.tar.bz2
When you run configure, you'll need to use the following to make sure
it uses the correct compiler.
     --target=i386-rtems
