[2] Help, VERY, VERY strange RTEMS execution time...
Alex
kbyte at iol.pt
Thu Mar 17 10:34:40 UTC 2005
Hi Adrian and first thanks for your help!
Well, I am using a intel celeron mendocino at 400MHz with 128k of cache
I turned off the CPU L1 cache and CPU L2 cache using the BIOS setup...
Without turn off any cache I saw the following values:
1440
56
56
56
56
54
56
56
56
56
When I turn off the L1 and L2 caches I saw
461
54
56
56
56
54
56
56
56
56
But as you said I just turn off the data caches, right?
Ok, I have to find out how to turn off the instruction cache and then try again to see the results...
Many thanks
Alex
> Hi,
> I doubt very much that you have disabled the instruction cache.
> I do not know what processor you are using, as i686 is not a
> processor name, but as this indicates a processor at least as
> recent as
> the Intel Pentium Pro, all such processors have at least three
> caches:
> level 1 instruction cache, level 1 data cache and level 2 data cache.
> All these caches are enabled and disabled separately, so I am
> curious what exactly have you done to disable all of them. If you
> just
> used some option in the BIOS Setup of the motherboard, then most
> BIOS'es
> only disable the data caches, so in that case the results you have
> measured are perfectly normal, because the instruction cache is
> still
> enabled. Therefore the first result corresponds to fetching the
> instructions from the main memory and the next values are for
> fetching
> from the instruction cache.
> Best regards !
______________________________________________________________________
Novo Servico IOL Dicionarios. 13 Linguas diferentes!
Saiba mais - http://www.iol.pt/correio/rodape.php?dst=0501251
