loopback sample problem
Grigori Khmyrov
Grigori_Khmyrov at uml.edu
Thu Mar 24 19:30:16 UTC 2005
Hi all,
I'm new user of RTEMS. I just installed it first time. I'm trying to run
sample programs from
/opt/build-rtems/i386-rtems/pc386/samples
It seems to me that the loopback.exe program doesn't work properly on the target computer:
HSB-657I
VIA C3 Eden CPU (i386 compatible processor)
Half-Size CPU Card
With LCD, Ethernet, PC/104 &
CompactFlash, USB
I load the sample using network and GRUB utility.
The loopback.exe output looks like:
"Network" initializing!
"Network" initialized!
Try running client with no server present.
Should fail with `connection refused'.
Connect to server.
Can't connect to server: Connection refused
Client closing connection.
Start server.
Try running client with server present.
Connect to server.
Client task terminating.
That's it.
I've tried loopback.exe from all BSP pc386, pc486, pc586, pc686, pck6.
All of them give me the same output.
Why is it? Any help appreciated.
I compiled rtems with options
/usr/local/src/rtems-4.6.2/configure --target=i386-rtems --disable-posix
--disable-itron --enable-tests --prefix=/opt/rtems-4.6
Thank you,
Grigori
