powerpc mvme5500 clock off by factor of 150
Kate Feng
feng1 at bnl.gov
Mon Mar 7 16:43:58 UTC 2005
"Joel Sherrill " wrote:
> Kate Feng wrote:
> > Peter Dufault wrote:
> >>The clock on the MVME5500 seems to be off by a factor of 150. In the
> >>"ticker" test it is taking 750 seconds instead of 5 seconds for the
> >>displays of the times. I started fiddling constants in bspstart.c but
> >>then reading the I2C bus started to fail so I decided I had to look
> >>through things and get an overview and not continue ignorantly.
> >>I'm looking through it now, but if anyone has hints based on knowledge
> >>of the PPC decrementer and the PPC board support packages and how they
> >>support the clock (or maybe changes that went into 4.7?) on where I
> >>should look I'd appreciate it.
> > I never tested the tests/samples/ticker. However, the mvme5500 clock
> > works fine for me. Attached is a test program I wrote. The test result
> > is:
> This is using rtems_bsp_delay. This is not the same as the
> ticker test which uses that the clock tick device driver.
> Look in tests/samples/ticker. You need to run it or
> you can't be sure any RTEMS time related service including
> timeouts on blocking, sleep, etc are right.
I really do not have to test tests/samples/ticker.
My EPICS application used blocking, sleep, etc.
As far as I am concerned, the clock works fine for all my
application.
Anyway, I replaced the rtems_bsp_delay() with
sc = rtems_task_wake_after( 5 * rtemsTicksPerSecond_double );
It works fine.
Ticks per second 100.000000
- rtems_clock_get - 09:00:05 03/07/2005
- rtems_clock_get - 09:00:10 03/07/2005
- rtems_clock_get - 09:00:15 03/07/2005
- rtems_clock_get - 09:00:20 03/07/2005
- rtems_clock_get - 09:00:25 03/07/2005
- rtems_clock_get - 09:00:30 03/07/2005
- rtems_clock_get - 09:00:35 03/07/2005
- rtems_clock_get - 09:00:40 03/07/2005
- rtems_clock_get - 09:00:45 03/07/2005
- rtems_clock_get - 09:00:50 03/07/2005
Regards,
Kate
