powerpc mvme5500 clock off by factor of 150
Peter Dufault dufault at hda.com
Tue Mar 8 00:01:27 UTC 2005
On Mar 7, 2005, at 1:30 PM, Till Straumann wrote:
> As far as I can see (looking at src in CVS) there is a bug in the BSP
> mvme5500/irq/irq.c comments the line (BSP_install_rtems_irq_handler())
>     * Enable interrupt on device
>        irq->on(irq);*/
> --> clockOn() is not called on this BSP. Note that eventually (i.e.,
> after the decrementer reaching zero from the initial 0xffffffff count
> [~250seconds at a decr/timebase clock rate of 16MHz]) the algorithm
> works normally. Since Kate is probably testing on a 'live' system
> using dynamic loading she is not observing the bug. Peter, however
> seems to work with the statically linked test app where the bug
> manifests itself.
> HTH
> -- T.
> Peter Dufault wrote:
>>> I do not have to test  tests/samples/ticker.  My EPICS applications
>>> use timeouts on blocking, sleep, etc.  The clock works fine on all my
>>> application.
>>> Anyway, I have a look at the code :
>>>     status = rtems_task_wake_after( task_index * 5 *
>>> get_ticks_per_second()
>>> Thus the time it takes is subject to the value of task_index.
>>> That is how he can get the factor of 5 seconds, right ?
>>> Peter, can you print out what the value of task_index is ?
>> If its off by 150, not by 5.  But where is the time base and
>> decrementer enabled?  The code to do that is in mpc6xx/mmu/mmuAsm.S
>> in the call to "L1_caches_enables", but the call to that is commented
>> out in mvme5500/startup/bspstart.c.
>> I tried just setting the bit in bspstart.c at that point but it
>> didn't help.
Well, I'm baffled by this.  As I mentioned, I can't enable that
"irq->on()" because I get a stack backtrace when it tries to call it
for the first IRQ, "main irq 56" with "exception handler called for
exception 7".
Also, I know "clockOn" is never called during startup because I put in
a dramatic "printk" when it is called and it isn't.
That means "PPC_Set_decrementer" isn't called with anything other than
the initial -1, and so the decrementer value should always be 2^32.
So I tried to forceably call clockOn, but regardless of what value I
load using PPC_Set_decrementer I see ticks about every 57 seconds (I
put a printk in the clock tick), at least when it starts up.
However, when interrupt driven I/O finally happens displaying the "TAx
- rtems_clock_get" stuff from the "ticker" task thinking five seconds
have gone by I see a burst of clock ticks, as if they are being driven
by the serial I/O interrupt.
I guess I need to get gdb working so I can see where the "tick"
interrupt is coming from.
Peter
Peter Dufault
HD Associates, Inc.
