powerpc mvme5500 clock off by factor of 150
Peter Dufault
dufault at hda.com
Tue Mar 8 12:56:03 UTC 2005
On Mar 8, 2005, at 7:07 AM, Peter Dufault wrote:
> if (excNum == ASM_DEC_VECTOR) {
> _CPU_MSR_GET(msr);
> new_msr = msr | MSR_EE;
> _CPU_MSR_SET(new_msr);
> rtems_hdl_tbl[BSP_DECREMENTER].hdl();
> _CPU_MSR_SET(msr);
> return;
> It looks to me as if we save the exception enable state, enable
> exceptions, call the handler, and then restore the exception state.
> What's the logic here? If exceptions are disabled, we enable them,
> the exception fires, we re-enter, call the handler once with
> exceptions enabled, return, call the handler a second time with
> exceptions still enabled, then disable exceptions? If exceptions are
> already enabled we call it once, and saving/restoring exception state
> is probably a NOP.
OK, I see what this is doing. Exceptions are usually disabled when we
enter this, we enable them after taking an exception so that a
higher-priority exception can pre-empt us.
I also put in a call to irq->on() in mvme5500/irq/irq.c in the case
that it is a processor exception, and it doesn't die on my and
clockOn() is called properly in that case. Still doesn't work though.
I've verified that:
. TBEN is set on the board to enable the decrementer to count (there is
a disable input on the processor);
. TBEN is set in HID0 to allow the decrementer to count and to
interrupt if MSR_EE is set;
. MSR_EE is set, and exceptions are initially enabled in the MSR when
the task starts;
. The decrementer is loaded with what corresponds to 10ms;
. Whenever I enter the decrementer handler exceptions are disabled in
the MSR, and given what I say above about the intent of the code loop,
that is correct.
So I don't understand why I only get an interrupt roughly every 35
seconds.
Peter
Peter Dufault
HD Associates, Inc.
