Clock not running (was Re: RTEMS4.7 and its tool chain (Re: powerpc mvme5500 clock off by factor of 150))
Peter Dufault
dufault at hda.com
Tue Mar 8 17:40:29 UTC 2005
On Mar 8, 2005, at 12:36 PM, Kate Feng wrote:
> How did the binary I sent you run on your mvme5500 ?
> If the clock is not running with the binary I sent you,
> then you should contact Motorla for repair.
It worked fine with your binary.
There is still an interrupt always firing on mine, though. Can you
decipher what that interrupt is from the output I posted before?
Peter
Peter Dufault
HD Associates, Inc.
