Clock not running (was Re: RTEMS4.7 and its tool chain (Re: powerpc mvme5500 clock off by factor of 150))
Peter Dufault
dufault at hda.com
Tue Mar 8 21:02:41 UTC 2005
On Mar 8, 2005, at 3:39 PM, Till Straumann wrote:
> Hence, you'd have to print the GPP_Interrupt_Cause register contents
> to find the culprit [why the code in irq.c is so complicated is a
> mystery to me].
The higher level code had derived register "56" as I'd mentioned, which
traced back to the serial port interrupt. Printing out the
ever-pending GPP_Interrupt_Cause is "0x01", which also points to the
serial port.
I wish there was a way to see that a PPC decrementer interrupt was
pending, because then I'd just call the decrementer ISR when interrupt
"56" was called and an interrupt was pending as a proof that this is
the problem, but I don't see that that is visible in any register.
On the web I see references to errata on the serial port on the
undocumented interface chip.
Peter
Peter Dufault
HD Associates, Inc.
