Clock not running (was Re: RTEMS4.7 and its tool chain (Re: powerpc mvme5500 clock off by factor of 150))
Peter Dufault
dufault at hda.com
Tue Mar 8 21:34:13 UTC 2005
On Mar 8, 2005, at 3:59 PM, Till Straumann wrote:
> OK, I wasn't careful enough, thinking that the GT_GPP_IntHandlers
> clear any pending interrupt
> used by the BSP [not -1 in config table]. However, the IRQ status is
> (who knows why) anded
> with the current mask at entry.
> --> if a serial IRQ is pending during init, the init code will mask
> GPP interrupts (but not clear any
> pending ones).
> --> pending irq ends up dispatching GT_GPP_IntHandler
> - if it's a 'configured' IRQ it is not cleared as long as no
> handler is installed (i.e., masked
> in the BSP 'cache').
> - if it's a 'unconfigured' IRQ it is never cleared.
> Try clearing all pending GPP irqs in 'BSP_rtems_irq_mngt_set()'
> (probably 'outl(0, BT_BPP_Int_Cause)') after the
> BSP_GPP_IRQ_LOWEST_OFFSET loop.
This doesn't look too promising as I understand you, since I do have a
serial port ISR installed.
The serial port ISR has been working great, until I tried to use the
network I was happily invoking functions and dumping data structures
over the serial port using "printf" and "cexp" while my servo loop ran
at 10KHz, and only when I tried to start using the network did I
realize that basic timing was broken. My data acquisition interrupt
must run at a higher priority than the serial port.
But since I don't understand the interrupt dispatch code either, I'll
try what you suggest.
Hmm. I don't see any BT_BPP_Int_Cause registers, there are three
G_GPP_Int{1,2,3}_Cause registers, that might be byte counterparts, I'll
try zeroing them after that loop.
OK, I zeroed the three registers after the loop. The front panel LED
is still lit at about 1/2 intensity, and the only place it is accessed
is when I xor it in C_dispatch_irq_handler right near the bottom when
it is calling rtems_hdl_tbl[irq].hdl() for the case "irq==56", which is
the serial port interrupt. So I think it is always going through that
interrupt.
Peter
Peter Dufault
HD Associates, Inc.
