rtems-CVS-050303 i.MX/MX1/csb336 BUG and BUGFIX
Pavel Pisa
ppisa4lists at pikron.com
Sun Mar 13 13:28:03 UTC 2005
Hello All,
I have found problems with clock and tick computation
on ARM CSB336.
There is integer overflow in get_perclk1_freq() for our
PLL setup. I have solved it by using "long long" type.
I hope that it is allowed/normal to use "long long" in RTEMS.
I have added rounding to timer setup to achieve more
exact timing.
I would be pleased, if changes are acceptable and could be
committed into official RTEMS tree. If you prefer and agree
on GNAT entry, I fill that.
Patch is copied as attachment for the case, that it is
malformed in the body.
Thanks for help
Pavel Pisa
e-mail: pisa at cmp.felk.cvut.cz
www: http://cmp.felk.cvut.cz/~pisa
work: http://www.pikron.com
diff --minimal -r -u -P -p rtems/c/src/lib/libcpu/arm/mc9328mxl/clock/clockdrv.c.orig rtems/c/src/lib/libcpu/arm/mc9328mxl/clock/clockdrv.c
--- rtems/c/src/lib/libcpu/arm/mc9328mxl/clock/clockdrv.c.orig 2005-01-30 17:24:50.000000000 +0100
+++ rtems/c/src/lib/libcpu/arm/mc9328mxl/clock/clockdrv.c 2005-03-05 01:31:47.000000000 +0100
@@ -82,7 +82,7 @@ rtems_irq_connect_data clock_isr_data =
int cnt; \
freq = get_perclk1_freq(); \
printk("perclk1 freq is %d\n", freq); \
- cnt = ((freq / 1000) * BSP_Configuration.microseconds_per_tick) / 1000;\
+ cnt = ((long long)freq * BSP_Configuration.microseconds_per_tick + 500000) / 1000000;\
printk("cnt freq is %d\n", cnt); \
MC9328MXL_TMR1_TCMP = cnt; \
/* use PERCLK1 as input, enable timer */ \
diff --minimal -r -u -P -p rtems/c/src/lib/libbsp/arm/csb336/startup/bspstart.c.orig rtems/c/src/lib/libbsp/arm/csb336/startup/bspstart.c
--- rtems/c/src/lib/libbsp/arm/csb336/startup/bspstart.c.orig 2005-01-30 17:24:11.000000000 +0100
+++ rtems/c/src/lib/libbsp/arm/csb336/startup/bspstart.c 2005-03-05 01:53:34.000000000 +0100
@@ -126,7 +126,7 @@ void bsp_start_default( void )
* The following information is very useful when debugging.
-#if 0
+#if 1
printk( "work_space_size = 0x%x\n",
BSP_Configuration.work_space_size );
printk( "maximum_extensions = 0x%x\n",
@@ -153,12 +153,12 @@ void bsp_start_default( void )
/* Calcuate the frequency for perclk1 */
int get_perclk1_freq(void)
- int fin;
- int fpll;
- int pd;
- int mfd;
- int mfi;
- int mfn;
+ unsigned int fin;
+ unsigned int fpll;
+ unsigned int pd;
+ unsigned int mfd;
+ unsigned int mfi;
+ unsigned int mfn;
uint32_t reg;
int perclk1;
@@ -187,13 +187,14 @@ int get_perclk1_freq(void)
printk("mfd = %d\n", mfd);
printk("mfi = %d\n", mfi);
printk("mfn = %d\n", mfn);
- printk("(fin * mfi) / (pd + 1) = %d\n", (fin * mfi) / (pd + 1));
- printk("(fin * mfn) / ((pd + 1) * (mfd + 1)) = %d\n",
- (fin * mfn) / ((pd + 1) * (mfd + 1)));
+ printk("rounded (fin * mfi) / (pd + 1) = %d\n", (fin * mfi) / (pd + 1));
+ printk("rounded (fin * mfn) / ((pd + 1) * (mfd + 1)) = %d\n",
+ ((long long)fin * mfn) / ((pd + 1) * (mfd + 1)));
#endif
- fpll = 2 * ( ((fin * mfi) / (pd + 1)) +
- ((fin * mfn) / ((pd + 1) * (mfd + 1))) );
+ fpll = 2 * ( ((fin * mfi + (pd + 1) / 2) / (pd + 1)) +
+ (((long long)fin * mfn + ((pd + 1) * (mfd + 1)) / 2) /
+ ((pd + 1) * (mfd + 1))) );
/* calculate the output of the PERCLK1 divider */
reg = MC9328MXL_PLL_PCDR;
Type: text/x-diff
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20050313/61b70efc/attachment-0001.bin>
