building rtems-cvs failed
Philippe Simons
loki_666 at fastmail.fm
Mon May 9 15:16:48 UTC 2005
Ok, I just tried to build RTEMS-CVS yesterday but whihout success...
I'm using autoconf-2.59.tar.bz2 with
autoconf-2.59-quoting-20040817-1.diff,
automake-1.9.5.tar.bz2 with automake-1.9.5-rtems-20050303.diff,
binutils-2.15.tar.bz2 with binutils-2.15-rtems-20040519.diff,
newlib-1.13.0.tar.gz with newlib-1.13.0-rtems-20050301.diff
and gcc-4.0.0.
the whole configured for target=arm-rtems
the rtems build process hangs, with some weird error from rpcgen when
building the rdbg directory (btw: which i dont want to use anyway)
I dont remember the exact error, but there was something about powerpc
exception api, which is really weird, since i'm build rtems for arm.
I even tried to configure rtems with --disable-rdbg, it doesnt change
anything.
Does anyone have a clue on this issue?
TIA
Philippe
