Closing a socket.
Thu May 12 03:20:47 UTC 2005
Till Straumann wrote:
> I agree. It's not OK to close a socket another thread is blocked on.
I think having a close unblock the thread and return an error code is
the best solution.
> Besides so->so_pgid, the surrounding/calling syscall (accept, ...)
> also accesses the already released socket struct.
Yes. I am looking at this.
> OTOH, deleting a blocked thread doesn't seem like a good solution either
This is a definite no no. Unless the networking lock is move to the TCB
and support added (which would be complex), it is not a good idea to
delete a thread making networking calls.
The rule I use is any thread that makes networking calls deletes itself.
> --> I believe the rtems syscalls should be changed to make it safe to
> close a socket on which another thread is blocking. This could be achieved
> e.g., by letting soconnsleep/soconnwakeup use different events if the
> socket is being closed and propagating  an error code that prevents
> the socket structure being from accessed from the RTEMS glue code
> in this case.
... or block the close until the blocked thread has returned. I have
something which appears to be working for accept, and I am now looking
at the other calls.
Using another event, say SOCLOSED is a good idea. I may look at this.
Thanks for the idea.
  Chris Johns
