CVS Access to 4.6.2 Trunk
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri May 13 18:31:57 UTC 2005
Brett Swimley wrote:
> Hi,
> I've started a new project and thought I'd upgrade to RTEMS 4.6.2.  That
> upgrade is working OK.  But, is there a way I can get the most  recent
> changes to 4.6.2 from cvs?  I'm not sure how to go about this.
> Is there a specific tag or branch that I can check out, or are all of
> the most recent changes going strictly into the 4.7 development path?
Since you know how to use the RTEMS anonymous CVS, the command should
be something like:
cvs -d CVSROOT rdiff -r rtems-4-6-2 diff -u >DIFFFILE
> Thanks,
> Brett Swimley
