Allocation of objects
SAUDUBRAY, Fabien
fabien.saudubray at astrium.eads.net
Wed May 18 11:31:54 UTC 2005
I'm not sure of my understanding :
Memory for objects is reserved, but is memory for objects allocated during
Initialization. (ie during _Objects_Initialize_information calls ? )
Because when we create an object (a task for example), the kernel calls the
_Object_Allocate directive which returns the first object in the Inactive
Chain of this kind of Object. But this implies that this Chain had been
allocated before ?
URL: <http://lists.rtems.org/pipermail/users/attachments/20050518/6a9ec4e0/attachment.html>
CE COURRIER ELECTRONIQUE EST A USAGE STRICTEMENT INFORMATIF ET NE SAURAIT ENGAGER DE QUELQUE MANIERE QUE CE SOIT EADS ASTRIUM SAS, NI SES FILIALES.
SI UNE ERREUR DE TRANSMISSION OU UNE ADRESSE ERRONEE A MAL DIRIGE CE COURRIER, MERCI D'EN INFORMER L'EXPEDITEUR EN LUI FAISANT UNE REPONSE PAR COURRIER ELECTRONIQUE DES RECEPTION. SI VOUS N'ETES PAS LE DESTINATAIRE DE CE COURRIER, VOUS NE DEVEZ PAS L'UTILISER, LE CONSERVER, EN FAIRE ETAT, LE DISTRIBUER, LE COPIER, L'IMPRIMER OU EN REVELER LE CONTENU A UNE TIERCE PARTIE.
This email is for information only and will not bind EADS Astrium SAS in any contract or obligation, nor its subsidiaries.
If you have received it in error, please notify the sender by return email. If you are not the addressee of this email, you must not use, keep, disseminate, copy, print or otherwise deal with it.
