Timer from ISR?
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Wed May 18 14:02:40 UTC 2005
leonp at plris.com wrote:
> Hello, gurus.
> 	A small question, which is missed in the docs (I did not find).
> 	May the timer directive rtems-timer_fire_after(..) be called from an ISR?
It is supposed to be OK.  TSRs themselves run in the clock tick ISR
so the intent is that you can at least reschedule them.
> 	Thanks ahead.
