Problems upgrading a BSP from RTEMS 4.5 to 4.6.2
Shadi T. Khasawneh
skhasaw1 at binghamton.edu
Thu May 19 01:18:22 UTC 2005
Hello all,
Thanks in advance for any help and suggestions.
I'm working on a research project using the RTEMS 4.6.2 on a RAMiX PMC694
card. The BSP is working fine under the 4.5, but the RTEMS is not
compiling under the 4.6.2.
This is what I have done so far (Please let me know if there is a better
way do do it):
1) Copied the old pmc694.cfg into make/custom, and modifed it to reflect
the new changes in 4.6.2 (based on some posts on this list).
2) Added the pmc694.cfg into make/custom/Makefile.am
3) Copied the pmc694 folder into c/src/lib/libbsp/powerpc/pmc694
3) Modifed the bsp_specs in pmc694/ to reflect the changes.
4) Created new Makefile.am and configure.ac files in pmc694/ and
Makefile.am files in the subfolders (the old version only had Makefile.in
files).
5) I have made a lot of changes/fixes to the Makefiles, and at the end I'm
stuck with the following error:
gmake[5]: Entering directory
`/shadi/rtems/bb/powerpc-rtems/c/pmc694/tests/samples/hello'
mkdir o-optimize
mkdir -p -- ../../../../../pmc694/tests
powerpc-rtems-gcc --pipe -B../../../../../lib/
-B../../../../../pmc694/lib/ -specs bsp_specs -qrtems
-DPACKAGE_NAME=\"rtems-c-src-tests-samples\"
-DPACKAGE_TARNAME=\"rtems-c-src-tests-samples\"
-DPACKAGE_VERSION=\"4.6.2\" -DPACKAGE_STRING=\"rtems-c-src-tests-samples\
4.6.2\" -DPACKAGE_BUGREPORT=\"rtems-bugs at rtems.com\" -isystem
../../../../../pmc694/lib/include -mcpu=603e
-DDONT_OFFLOAD_RX_CHECKSUM -DDONT_OFFLOAD_TX_CHECKSUM -Dppc603e -O4
-fno-keep-inline-functions -g -Wall -ansi -fasm -o o-optimize/init.o -c
../../../../../../../rtems-4.6.2/c/src/tests/samples/hello/init.c
-B../../../../../pmc694/lib/ -specs bsp_specs -qrtems -mcpu=603e
-Wl,-Map,o-optimize/hello.map -o o-optimize/hello.elf o-optimize/init.o
../../../../../pmc694/lib/no-dpmem.rel
../../../../../pmc694/lib/no-event.rel
../../../../../pmc694/lib/no-msg.rel ../../../../../pmc694/lib/no-mp.rel
../../../../../pmc694/lib/no-part.rel
../../../../../pmc694/lib/no-signal.rel
../../../../../pmc694/lib/no-timer.rel
../../../../../pmc694/lib/no-rtmon.rel
/opt/rtems-4.6/lib/gcc-lib/powerpc-rtems/3.2.3/../../../../powerpc-rtems/bin/ld:
warning: no memory region specified for section `.eh_frame'
../../../../../pmc694/lib/librtemsbsp.a(bootcard.o): In function `boot_card':
/shadi/rtems/bb/powerpc-rtems/c/pmc694/lib/libbsp/powerpc/pmc694/startup/../../../../../../../../../rtems-4.6.2/c/src/lib/libbsp/powerpc/pmc694/startup/bootcard.c:128:
undefined reference to `main'
../../../../../pmc694/lib/librtemsbsp.a(Hwr_init.o): In function `init_BAT':
/shadi/rtems/bb/powerpc-rtems/c/pmc694/lib/libbsp/powerpc/pmc694/startup/../../../../../../../../../rtems-4.6.2/c/src/lib/libbsp/powerpc/pmc694/startup/Hwr_init.c:149:
undefined reference to `rxPciConfWrite'
/shadi/rtems/bb/powerpc-rtems/c/pmc694/lib/libbsp/powerpc/pmc694/startup/../../../../../../../../../rtems-4.6.2/c/src/lib/libbsp/powerpc/pmc694/startup/Hwr_init.c:151:
/shadi/rtems/bb/powerpc-rtems/c/pmc694/lib/libbsp/powerpc/pmc694/startup/../../../../../../../../../rtems-4.6.2/c/src/lib/libbsp/powerpc/pmc694/startup/Hwr_init.c:159:
../../../../../pmc694/lib/librtemscpu.a(exinit.o): In function
`rtems_initialize_executive_early':
/shadi/rtems/bb/powerpc-rtems/c/pmc694/exec/sapi/../../../../../../rtems-4.6.2/cpukit/sapi/src/exinit.c:151:
undefined reference to `_CPU_Initialize'
`rtems_shutdown_executive':
/shadi/rtems/bb/powerpc-rtems/c/pmc694/exec/sapi/../../../../pmc694/lib/include/rtems/score/thread.inl:32:
undefined reference to `_CPU_Context_switch'
../../../../../pmc694/lib/librtemscpu.a(interr.o): In function
`_Internal_error_Occurred':
/shadi/rtems/bb/powerpc-rtems/c/pmc694/exec/score/../../../../../../rtems-4.6.2/cpukit/score/src/interr.c:57:
undefined reference to `_BSP_Fatal_error'
../../../../../pmc694/lib/librtemscpu.a(intrcatch.o): In function
`rtems_interrupt_catch':
/shadi/rtems/bb/powerpc-rtems/c/pmc694/exec/rtems/../../../../../../rtems-4.6.2/cpukit/rtems/src/intrcatch.c:51:
undefined reference to `BSP_panic'
../../../../../pmc694/lib/librtemscpu.a(threaddispatch.o): In function
`_Thread_Dispatch':
/shadi/rtems/bb/powerpc-rtems/c/pmc694/exec/score/../../../../../../rtems-4.6.2/cpukit/score/src/threaddispatch.c:109:
/shadi/rtems/bb/powerpc-rtems/c/pmc694/exec/score/../../../../../../rtems-4.6.2/cpukit/score/src/threaddispatch.c:121:
undefined reference to `_CPU_Context_restore_fp'
/shadi/rtems/bb/powerpc-rtems/c/pmc694/exec/score/../../../../../../rtems-4.6.2/cpukit/score/src/threaddispatch.c:105:
undefined reference to `_CPU_Context_save_fp'
../../../../../pmc694/lib/librtemscpu.a(threadstartmultitasking.o): In
function `_Thread_Start_multitasking':
/shadi/rtems/bb/powerpc-rtems/c/pmc694/exec/score/../../../../../../rtems-4.6.2/cpukit/score/src/threadstartmultitasking.c:88:
/shadi/rtems/bb/powerpc-rtems/c/pmc694/exec/score/../../../../../../rtems-4.6.2/cpukit/score/src/threadstartmultitasking.c:85:
../../../../../pmc694/lib/librtemscpu.a(threadloadenv.o): In function
`_Thread_Load_environment':
/shadi/rtems/bb/powerpc-rtems/c/pmc694/exec/score/../../../../../../rtems-4.6.2/cpukit/score/src/threadloadenv.c:70:
undefined reference to `_CPU_Context_Initialize'
../../../../../pmc694/lib/librtemscpu.a(threadhandler.o): In function
`_Thread_Handler':
/shadi/rtems/bb/powerpc-rtems/c/pmc694/exec/score/../../../../../../rtems-4.6.2/cpukit/score/src/threadhandler.c:112:
undefined reference to `_init'
/shadi/rtems/bb/powerpc-rtems/c/pmc694/exec/score/../../../../../../rtems-4.6.2/cpukit/score/src/threadhandler.c:113:
collect2: ld returned 1 exit status
gmake[5]: *** [o-optimize/hello.exe] Error 1
gmake[5]: Leaving directory
gmake[4]: *** [all-recursive] Error 1
gmake[4]: Leaving directory
`/shadi/rtems/bb/powerpc-rtems/c/pmc694/tests/samples'
gmake[3]: *** [all-recursive] Error 1
gmake[3]: Leaving directory `/shadi/rtems/bb/powerpc-rtems/c/pmc694/tests'
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory `/shadi/rtems/bb/powerpc-rtems/c/pmc694'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/shadi/rtems/bb/powerpc-rtems/c'
gmake: *** [all-recursive] Error 1
=> bsp_specs (modified file):
%rename lib old_lib
%rename endfile old_endfile
%rename startfile old_startfile
%rename link old_link
*lib:
%{!qrtems: %(old_lib)} %{!nostdlib: %{qrtems: --start-group \
%{!qrtems_debug: -lrtemsbsp -lrtemscpu} %{qrtems_debug: -lrtemsbsp_g
-lrtemscpu_g} \
-lc -lgcc --end-group \
%{!qnolinkcmds: -T linkcmds%s}}}
*startfile:
%{!qrtems: %(old_startfile)} %{!nostdlib: %{qrtems: ecrti%O%s \
%{!qrtems_debug: start.o%s} \
%{qrtems_debug: start_g.o%s}}}
*endfile:
%{!qrtems: %(old_endfile)} %{qrtems: ecrtn%O%s}
*link:
%{!qrtems: %(old_link)} %{qrtems: -Qy -dp -Bstatic -e _start -u __vectors}
=> pmc694.cfg (modified file)
# Config file for a MPC8240 based RAMiX PMC694 intelligent ethernet card.
# $Id: pmc694.cfg,v 1.1 2002/02/11 10:09:21 johnc Exp $
RTEMS_CPU=powerpc
RTEMS_CPU_MODEL=ppc603e
#PROJECT_TOOLS=$(PROJECT_ROOT)/c/build-tools/scripts
# This is the actual bsp directory used during the build process.
RTEMS_BSP_FAMILY=pmc694
RTEMS_BSP=pmc694
include $(RTEMS_ROOT)/make/custom/default.cfg
# We can use DEFINES to enable debugging macros
DEFINES = # -DDEBUG_INCR
# This section makes the target dependent options file.
# NDEBUG (C library)
# if defined asserts do not generate code. This is commonly used
# as a command line option.
# RTEMS_TEST_NO_PAUSE (RTEMS tests)
# do not pause between screens of output in the rtems tests
# STACK_CHECKER_ON (RTEMS support code)
# If defined, stack bounds checking is enabled.
# STACK_CHECKER_REPORT_USAGE (RTEMS support code)
# If this and STACK_CHECKER_ON are defined, then a report on stack usage
# per task is printed when the program exits.
# RTEMS_DEBUG (RTEMS)
# If defined, debug checks in RTEMS and support library code are enabled.
# CONSOLE_USE_INTERRUPTS (pmc694_bsp)
# The pmc694 console driver has the structure to operate in either
# polled or interrupt mode. However both modes only trap to the
# monitor currently.
# PPC_USE_DATA_CACHE (RTEMS PowerPC port)
# If defined, then the PowerPC specific code in RTEMS will use
# data cache instructions to optimize the context switch code.
# This code can conflict with debuggers or emulators.
# PPC_VECTOR_FILE_BASE (ppc)
# This defines the base address of the exception table.
# NOTE: Vectors are actually at 0xFFF00000 but file starts at offset
0x0100
# PPC_ABI (ppc)
# This defines the calling convention (Application Binary Interface)
# used in this configuration. EABI is the only one supported.
# PPC_ASM (ppc)
# This defines the assembly language format used in this configuration.
# ELF is the only one supported.
# PPC_USE_SPRG (RTEMS PowerPC port)
# If defined, then the PowerPC specific code in RTEMS will use some
# of the special purpose registers to slightly optimize interrupt
# response time. The use of these registers can conflict with
# other tools like debuggers.
define make-target-options
@echo "/* #define NDEBUG 1 */ " >>$@
@echo "#define RTEMS_TEST_NO_PAUSE 1" >>$@
@echo "/* #define STACK_CHECKER_ON 1 */"
@echo "/* #define STACK_CHECKER_REPORT_USAGE 1 */"
@echo "/* #define RTEMS_DEBUG 1 */" >>$@
@echo "#define CONSOLE_USE_INTERRUPTS 4" >>$@
@echo "#define INITIALIZE_COM_PORTS 1" >>$@
@echo "#define PPC_USE_DATA_CACHE 0" >>$@
@echo "#define PPC_VECTOR_FILE_BASE 0x0100" >>$@
@echo "#define PPC_ABI PPC_ABI_EABI" >>$@
@echo "#define PPC_ASM PPC_ASM_ELF" >>$@
@echo "#define PPC_USE_SPRG 0" >>$@
endef
# This contains the compiler options necessary to select the CPU model
# and (hopefully) optimize for it.
# Modified by Shailesh to disable DMA Copying..
CPU_CFLAGS = -mcpu=603e \
#CPU_CFLAGS = -mcpu=603 \
# -DDONT_OFFLOAD_RX_CHECKSUM
-DDONT_OFFLOAD_TX_CHECKSUM \
# -DNO_USERSPACE_COPY
# optimize flag: typically -0, could use -O4 or -fast
# -O4 is ok for RTEMS
# NOTE: some level of -O may be actually required by inline assembler
CFLAGS_OPTIMIZE_V=-O4 -fno-keep-inline-functions
# CFLAGS_OPTIMIZE_V=-O0
# This target does not support the ka9q tcp/ip stack so ignore requests
# to enable it.
HAS_NETWORKING=yes
# The following is a linkcmds file which will work without using the
# -specs system in gcc 2.8.
# $(LD) $(XLDFLAGS) -T $(LINKCMDS) \
# -o $@ -u atexit -u __vectors -u download_entry $(LINK_FILES)
# $(LD) $(XLDFLAGS) -Ttext 0x20000 \
#ifeq ($(RTEMS_USE_GCC272),yes)
#define make-exe
# @echo gcc 2.7.2 style linking not supported by score603e
# @exit 1
#endef
#else
define make-exe
$(CC) $(CPPFLAGS) $(CFLAGS) -Wl,-Map,$(basename $@).map \
-o $(basename $@).elf $(LINK_OBJS) $(LINK_LIBS)
$(NM) -g -n $(basename $@).elf > $(basename $@).num
$(SIZE) $(basename $@).elf
$(OBJCOPY) -O binary $(basename $@).elf $(basename $@).bin
sed -e 's/.$$//' $(basename $@).bin | \
$(PACKHEX) >$(basename $@).exe
#rm -f $(basename $@).s1
rm -f *.o
endef
#define make-exe
# ar x $(PROJECT_ROOT)/$(RTEMS_BSP_FAMILY)/lib/libbsp.a
# $(LD) -u _sbrk $(LDFLAGS) -Map $(basename $@).map -N -T
$(LINKCMDS) -o $(basename $@).exe \
# $(START_FILE) $(LINK_OBJS) --start-group $(LINK_LIBS)
--end-group
# $(NM) -g -n $(basename $@).exe > $(basename $@).num
# $(LD) -u _sbrk $(LDFLAGS) -oformat binary -N -T $(LINKCMDS) -o
$(basename $@).bin \
--end-group
# $(SIZE) $(basename $@).exe
# rm -f *.o
#endef
#endif
# Miscellaneous additions go here
# No start file
START_BASE=
DRIVER_ARCHITECTURE=
Thanks,
Shadi
______________________________________
Shadi T. Khasawneh
Graduate Research Associate/Endicott Interconnect Technologies
Department of Computer Science
State University of New York at Binghamton
P.O. Box 6000
Binghamton, New York 13902-6000
E-mail: skhasaw1 at binghamton.edu
