TSR's
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Thu May 19 19:50:26 UTC 2005
Mike Bertosh wrote:
> Hi all,
> I am calling a function inside my TSR that tries to obtain the network semaphore.
> When this happens my program crashes in the internal error function. Am I allowed to
> get the network semaphore from inside the TSR?
no, no, no and no. :)
If you do not acquire the network semaphore, the caller will block.  A
TSR runs in the clock tick ISR -- not a task.  That error check is in
there just to prevent the weird errors you would get if you blocked in
the middle of an ISR.
I don't know what you are trying to accomplish but you probably want to
wakeup a task to do it.  Most of the network drivers have to do this to
defer some processing to task level for this very reason.
 > Any help would be greatly
> appreciated. Thanks for your time.
> Mike Bertosh
> Motion Control Systems, Inc.
> New River, Va
> 540.731.0540
