Problems upgrading a BSP from RTEMS 4.5 to 4.6.2
Shadi T. Khasawneh skhasaw1 at binghamton.edu
Fri May 20 15:35:25 UTC 2005
Now, after doing the suggested modifications, I'm getting the following
errors:
Errors when using the original linkcmds (the one copied from 4.5):
mkdir -p --
../../../../../pmc694/tests
powerpc-rtems-gcc --pipe -B../../../../../lib/
-B../../../../../pmc694/lib/ -specs bsp_specs -qrtems
-DPACKAGE_NAME=\"rtems-c-src-tests-samples\"
-DPACKAGE_TARNAME=\"rtems-c-src-tests-samples\"
-DPACKAGE_VERSION=\"4.6.2\" -DPACKAGE_STRING=\"rtems-c-src-tests-samples\
4.6.2\"
-DPACKAGE_BUGREPORT=\"rtems-bugs at rtems.com\"    -isystem
../../../../../pmc694/lib/include     -mcpu=603e
-DDONT_OFFLOAD_RX_CHECKSUM -DDONT_OFFLOAD_TX_CHECKSUM -Dppc603e
-D_OLD_EXCEPTIONS  -O4 -fno-keep-inline-functions -g -Wall -ansi -fasm  -o
o-optimize/init.o -c
../../../../../../../rtems-4.6.2/c/src/tests/samples/hello/init.c
-B../../../../../pmc694/lib/ -specs bsp_specs -qrtems    -mcpu=603e
-Wl,-Map,o-optimize/hello.map -o o-optimize/hello.elf o-optimize/init.o
../../../../../pmc694/lib/no-dpmem.rel
../../../../../pmc694/lib/no-event.rel
../../../../../pmc694/lib/no-msg.rel ../../../../../pmc694/lib/no-mp.rel
../../../../../pmc694/lib/no-part.rel
../../../../../pmc694/lib/no-signal.rel
../../../../../pmc694/lib/no-timer.rel
../../../../../pmc694/lib/no-rtmon.rel
../../../../../pmc694/lib/no-event.rel: In function `s.got':
no-event.c(*ABS*+0x100064): multiple definition of `_etext'
no-event.c(*ABS*+0x100064): multiple definition of `_edata'
../../../../../pmc694/lib/no-event.rel: In function `_end':
no-event.c(*ABS*+0x108068): multiple definition of `_end'
no-event.c(*ABS*+0x100064): multiple definition of `s.got'
../../../../../pmc694/lib/no-msg.rel: In function `s.got':
no-msg.c(*ABS*+0x100214): multiple definition of `_etext'
no-msg.c(*ABS*+0x100214): multiple definition of `_edata'
../../../../../pmc694/lib/no-msg.rel: In function `_end':
no-msg.c(*ABS*+0x108218): multiple definition of `_end'
no-msg.c(*ABS*+0x100214): multiple definition of `s.got'
../../../../../pmc694/lib/no-mp.rel: In function `s.got':
no-mp.c(*ABS*+0x100000): multiple definition of `_etext'
no-mp.c(*ABS*+0x100000): multiple definition of `_edata'
../../../../../pmc694/lib/no-mp.rel: In function `_end':
no-mp.c(*ABS*+0x108008): multiple definition of `_end'
no-mp.c(*ABS*+0x100000): multiple definition of `s.got'
../../../../../pmc694/lib/no-signal.rel: In function `s.got':
no-signal.c(*ABS*+0x100064): multiple definition of `_etext'
no-signal.c(*ABS*+0x100064): multiple definition of `_edata'
../../../../../pmc694/lib/no-signal.rel: In function `_end':
no-signal.c(*ABS*+0x108068): multiple definition of `_end'
no-signal.c(*ABS*+0x100064): multiple definition of `s.got'
../../../../../pmc694/lib/no-timer.rel: In function `s.got':
no-timer.c(*ABS*+0x100154): multiple definition of `_etext'
no-timer.c(*ABS*+0x100154): multiple definition of `_edata'
../../../../../pmc694/lib/no-timer.rel: In function `_end':
no-timer.c(*ABS*+0x108158): multiple definition of `_end'
no-timer.c(*ABS*+0x100154): multiple definition of `s.got'
../../../../../pmc694/lib/no-rtmon.rel: In function `s.got':
no-rtmon.c(*ABS*+0x100150): multiple definition of `_etext'
no-rtmon.c(*ABS*+0x100150): multiple definition of `_edata'
../../../../../pmc694/lib/no-rtmon.rel: In function `_end':
no-rtmon.c(*ABS*+0x108150): multiple definition of `_end'
no-rtmon.c(*ABS*+0x100150): multiple definition of `s.got'
../../../../../pmc694/lib/librtemsbsp.a(bcopy.o): In function `strlen':
bcopy.o(.text+0x94): multiple definition of `strlen'
/opt/rtems-4.6/lib/gcc-lib/powerpc-rtems/3.2.3/../../../../powerpc-rtems/lib/m603e/roe/libc.a(strlen.o):/home/rtems/src/packages/BUILD/rtems-4.6-powerpc-rtems-gcc-newlib-gcc3.2.3newlib1.11.0/build/powerpc-rtems/m603e/roe/newlib/libc/string/../../../../../../../gcc-3.2.3/newlib/libc/string/strlen.c:71:
first defined here
../../../../../pmc694/lib/librtemsbsp.a(rtems-cpu.rel): In function `s.got':
<built-in>(*ABS*+0x1009bc): multiple definition of `_etext'
../../../../../pmc694/lib/librtemsbsp.a(rtems-cpu.rel): In function `_edata':
<built-in>(*ABS*+0x1009c4): multiple definition of `_edata'
../../../../../pmc694/lib/librtemsbsp.a(rtems-cpu.rel): In function `_end':
<built-in>(*ABS*+0x1089c8): multiple definition of `_end'
<built-in>(*ABS*+0x1009bc): multiple definition of `s.got'
/opt/rtems-4.6/lib/gcc-lib/powerpc-rtems/3.2.3/../../../../powerpc-rtems/bin/ld:
warning: no memory region specified for section `.eh_frame'
../../../../../pmc694/lib/librtemscpu.a(threadhandler.o): In function
`_Thread_Handler':
/shadi/rtems/bb/powerpc-rtems/c/pmc694/exec/score/../../../../../../rtems-4.6.2/cpukit/score/src/threadhandler.c:112:
undefined reference to `_init'
/shadi/rtems/bb/powerpc-rtems/c/pmc694/exec/score/../../../../../../rtems-4.6.2/cpukit/score/src/threadhandler.c:113:
collect2: ld returned 1 exit status
gmake[5]: *** [o-optimize/hello.exe] Error 1
gmake[5]: Leaving directory
`/shadi/rtems/bb/powerpc-rtems/c/pmc694/tests/samples/hello'
gmake[4]: *** [all-recursive] Error 1
gmake[4]: Leaving directory
`/shadi/rtems/bb/powerpc-rtems/c/pmc694/tests/samples'
gmake[3]: *** [all-recursive] Error 1
gmake[3]: Leaving directory `/shadi/rtems/bb/powerpc-rtems/c/pmc694/tests'
gmake[2]:
gmake[2]: Leaving directory `/shadi/rtems/bb/powerpc-rtems/c/pmc694'
gmake[1]: ***
gmake[1]: Leaving directory `/shadi/rtems/bb/powerpc-rtems/c'
gmake: *** [all-recursive] Error 1
Error using score603e linkcmds:
4.6.2\"
../../../../../pmc694/lib/no-dpmem.rel: In function `__init':
../../../../../pmc694/lib/no-dpmem.rel(.init+0x0): multiple definition of
`__init'
/opt/rtems-4.6/lib/gcc-lib/powerpc-rtems/3.2.3/m603e/roe/ecrti.o(.init+0x0):
first
defined here
../../../../../pmc694/lib/no-dpmem.rel: In function `__fini':
../../../../../pmc694/lib/no-dpmem.rel(.fini+0x0): multiple definition of
`__fini'
/opt/rtems-4.6/lib/gcc-lib/powerpc-rtems/3.2.3/m603e/roe/ecrti.o(.fini+0x0):
first
defined here
`__stop_set_sysctl_set':
no-event.c(*ABS*+0x100070): multiple definition of `_etext'
../../../../../pmc694/lib/no-event.rel: In function `__init':
../../../../../pmc694/lib/no-event.rel(.init+0x0): multiple definition of
`_init'
../../../../../pmc694/lib/no-dpmem.rel(.init+0x0): first defined here
`__init'
first
defined here
`__start_set_sysctl_set':
../../../../../pmc694/lib/no-event.rel(.text+0x70): multiple definition of
../../../../../pmc694/lib/no-dpmem.rel(.text+0x100): first defined here
no-event.c(*ABS*+0x100070): multiple definition of `__stop_set_sysctl_set'
../../../../../pmc694/lib/no-event.rel: In function `__fini':
../../../../../pmc694/lib/no-event.rel(.fini+0x0): multiple definition of
`_fini'
../../../../../pmc694/lib/no-dpmem.rel(.fini+0x0): first defined here
`__fini'
first
defined here
../../../../../pmc694/lib/no-event.rel: In function `_edata':
../../../../../pmc694/lib/no-event.rel(.sdata+0x0): multiple definition of
`_edata'
../../../../../pmc694/lib/no-dpmem.rel(.sdata+0x0): first defined here
../../../../../pmc694/lib/no-event.rel(.bss+0x8000): multiple definition
of `_end'
../../../../../pmc694/lib/no-dpmem.rel(.bss+0x8000): first defined here
../../../../../pmc694/lib/no-event.rel(.got+0x0): multiple definition of
`s.got'
../../../../../pmc694/lib/no-dpmem.rel(.got+0x0): first defined here
../../../../../pmc694/lib/no-msg.rel: In function `__stop_set_sysctl_set':
no-msg.c(*ABS*+0x100220): multiple definition of `_etext'
../../../../../pmc694/lib/no-msg.rel: In function `__init':
../../../../../pmc694/lib/no-msg.rel(.init+0x0): multiple definition of
`_init'
`__init'
first
defined here
../../../../../pmc694/lib/no-msg.rel(.text+0x220): multiple definition of
no-msg.c(*ABS*+0x100220): multiple definition of `__stop_set_sysctl_set'
../../../../../pmc694/lib/no-msg.rel: In function `__fini':
../../../../../pmc694/lib/no-msg.rel(.fini+0x0): multiple definition of
`_fini'
`__fini'
first
defined here
../../../../../pmc694/lib/no-msg.rel: In function `_edata':
../../../../../pmc694/lib/no-msg.rel(.sdata+0x0): multiple definition of
`_edata'
../../../../../pmc694/lib/no-msg.rel(.bss+0x8000): multiple definition of
`_end'
../../../../../pmc694/lib/no-msg.rel(.got+0x0): multiple definition of
`s.got'
../../../../../pmc694/lib/no-mp.rel: In function `__stop_set_sysctl_set':
../../../../../pmc694/lib/no-mp.rel: In function `__init':
../../../../../pmc694/lib/no-mp.rel(.init+0x0): multiple definition of
`_init'
`__init'
first
defined here
../../../../../pmc694/lib/no-mp.rel: In function `__start_set_sysctl_set':
../../../../../pmc694/lib/no-mp.rel(.text+0x0): multiple definition of
no-mp.c(*ABS*+0x100000): multiple definition of `__stop_set_sysctl_set'
../../../../../pmc694/lib/no-mp.rel: In function `__fini':
../../../../../pmc694/lib/no-mp.rel(.fini+0x0): multiple definition of
`_fini'
`__fini'
first
defined here
../../../../../pmc694/lib/no-mp.rel: In function `_edata':
../../../../../pmc694/lib/no-mp.rel(.sdata+0x0): multiple definition of
`_edata'
../../../../../pmc694/lib/no-mp.rel(.bss+0x8008): multiple definition of
`_end'
../../../../../pmc694/lib/no-mp.rel(.got+0x0): multiple definition of `s.got'
../../../../../pmc694/lib/no-part.rel: In function `__init':
../../../../../pmc694/lib/no-part.rel(.init+0x0): multiple definition of
`_init'
`__init'
first
defined here
../../../../../pmc694/lib/no-part.rel(.text+0x100): multiple definition of
../../../../../pmc694/lib/no-part.rel: In function `__fini':
../../../../../pmc694/lib/no-part.rel(.fini+0x0): multiple definition of
`_fini'
`__fini'
first
defined here
../../../../../pmc694/lib/no-part.rel: In function `_edata':
../../../../../pmc694/lib/no-part.rel(.sdata+0x0): multiple definition of
`_edata'
../../../../../pmc694/lib/no-part.rel: In function `_end':
../../../../../pmc694/lib/no-part.rel(.bss+0x8000): multiple definition of
`_end'
../../../../../pmc694/lib/no-part.rel: In function `s.got':
../../../../../pmc694/lib/no-part.rel(.got+0x0): multiple definition of
`s.got'
no-signal.c(*ABS*+0x100070): multiple definition of `_etext'
../../../../../pmc694/lib/no-signal.rel: In function `__init':
../../../../../pmc694/lib/no-signal.rel(.init+0x0): multiple definition of
`_init'
`__init'
first
defined here
../../../../../pmc694/lib/no-signal.rel(.text+0x70): multiple definition of
../../../../../pmc694/lib/no-signal.rel: In function `__fini':
../../../../../pmc694/lib/no-signal.rel(.fini+0x0): multiple definition of
`_fini'
`__fini'
first
defined here
../../../../../pmc694/lib/no-signal.rel: In function `_edata':
../../../../../pmc694/lib/no-signal.rel(.sdata+0x0): multiple definition
of `_edata'
../../../../../pmc694/lib/no-signal.rel(.bss+0x8000): multiple definition
of `_end'
../../../../../pmc694/lib/no-signal.rel(.got+0x0): multiple definition of
`s.got'
no-timer.c(*ABS*+0x100160): multiple definition of `_etext'
../../../../../pmc694/lib/no-timer.rel: In function `__init':
../../../../../pmc694/lib/no-timer.rel(.init+0x0): multiple definition of
`_init'
`__init'
first
defined here
../../../../../pmc694/lib/no-timer.rel(.text+0x160): multiple definition of
no-timer.c(*ABS*+0x100160): multiple definition of `__stop_set_sysctl_set'
../../../../../pmc694/lib/no-timer.rel: In function `__fini':
../../../../../pmc694/lib/no-timer.rel(.fini+0x0): multiple definition of
`_fini'
`__fini'
first
defined here
../../../../../pmc694/lib/no-timer.rel: In function `_edata':
../../../../../pmc694/lib/no-timer.rel(.sdata+0x0): multiple definition of
`_edata'
../../../../../pmc694/lib/no-timer.rel(.bss+0x8000): multiple definition
of `_end'
../../../../../pmc694/lib/no-timer.rel(.got+0x0): multiple definition of
`s.got'
../../../../../pmc694/lib/no-rtmon.rel: In function `__init':
../../../../../pmc694/lib/no-rtmon.rel(.init+0x0): multiple definition of
`_init'
`__init'
first
defined here
../../../../../pmc694/lib/no-rtmon.rel(.text+0x150): multiple definition of
no-rtmon.c(*ABS*+0x100150): multiple definition of `__stop_set_sysctl_set'
../../../../../pmc694/lib/no-rtmon.rel: In function `__fini':
../../../../../pmc694/lib/no-rtmon.rel(.fini+0x0): multiple definition of
`_fini'
`__fini'
first
defined here
../../../../../pmc694/lib/no-rtmon.rel: In function `_edata':
../../../../../pmc694/lib/no-rtmon.rel(.sdata+0x0): multiple definition of
`_edata'
../../../../../pmc694/lib/no-rtmon.rel(.bss+0x8000): multiple definition
of `_end'
../../../../../pmc694/lib/no-rtmon.rel(.got+0x0): multiple definition of
`s.got'
first defined here
../../../../../pmc694/lib/librtemsbsp.a(rtems-cpu.rel): In function `_etext':
../../../../../pmc694/lib/librtemsbsp.a(rtems-cpu.rel): In function `__init':
rtems-cpu.rel(.init+0x0): multiple definition of `_init'
rtems-cpu.rel(.init+0x0): multiple definition of `__init'
first
defined here
rtems-cpu.rel(.text+0x960): multiple definition of
<built-in>(*ABS*+0x100960): multiple definition of `__stop_set_sysctl_set'
../../../../../pmc694/lib/librtemsbsp.a(rtems-cpu.rel): In function `__fini':
rtems-cpu.rel(.fini+0x0): multiple definition of `_fini'
rtems-cpu.rel(.fini+0x0): multiple definition of `__fini'
first
defined here
rtems-cpu.rel(.sdata+0x8): multiple definition of `_edata'
rtems-cpu.rel(.bss+0x8004): multiple definition of `_end'
rtems-cpu.rel(.got+0x0): multiple definition of `s.got'
collect2: ld
gmake[2]:
gmake[1]: ***
RAMiX provided a SDK which included the RTEMS 4.5, and one of the
libraries was outside the source-tree; and this was causing the missing
functions errors previously (but not anymore - since I added them to the
lib).
It was mentioned before that the linkcmds file is generated automatically.
Since I have the source, can I re-generate it again?
> I went to Owego on a business trip years ago which meant I had to fly
> into Binghamton.  Is the airport there still terribly small?
> --joel
Yes, it is improved a little, but it is still quite small.
Thanks,
Shadi
