How to set what managers will be in RTEMS?
Ali Asgar Nasir aliasgar.nasir at patni.com
Mon May 23 03:51:17 UTC 2005
in your make file there will be a line which starts by the word "MANAGERS  =
io" ..u can add what managers u want on this line..... for eg if u require
semaphores and messaeg que managers then the line will look like "MANAGERS =
io message semaphore"...this make is in the o-optimize folder of your
application.
----- Original Message -----
From: "Fabrício de Novaes Kucinskis" <fabricio at dea.inpe.br>
To: "RTEMS - Mailing List" <rtems-users at rtems.com>
Sent: Friday, May 20, 2005 5:37 PM
Subject: How to set what managers will be in RTEMS?
> Hi all,
> I'm new to RTEMS, and I have to configure RTEMS 4.0.0 to work with a
Tharsys
> RT SBC.
> I'd like to know how to set the managers I want to disable. I read the
> documentation, but it still not clear to me. Is it done using a
> Configuration Table? Or with parameters when running configure?
> Another question: is it possible to disable POSIX managers?
> And, finally, when I build RTEMS with the POSIX API, the Classic API
remains
> on the OS or it is replaced by the POSIX API?
> Thank you in advance,
> Fabrício de Novaes Kucinskis - DEA / INPE
> Divisão de Eletrônica Aeroespacial
> Instituto Nacional de Pesquisas Espaciais
http://www.patni.com
World-Wide Partnerships. World-Class Solutions.
_____________________________________________________________________
This e-mail message may contain proprietary, confidential or legally
privileged information for the sole use of the person or entity to
whom this message was originally addressed. Any review, e-transmission
dissemination or other use of or taking of any action in reliance upon
this information by persons or entities other than the intended
recipient is prohibited. If you have received this e-mail in error
kindly delete  this e-mail from your records. If it appears that this
mail has been forwarded to you without proper authority, please notify
us immediately at netadmin at patni.com and delete this mail.
