Stack filling.
Fri May 27 06:34:48 UTC 2005
Hello,
I would like to change the score to fill the stack of a new task with a
value so stack usage can be estimated.
This allows the capture engine to show the stack usage on tasks created
before the capture engine has been initialised. I also means the RTEMS
monitor can show usage without the need for an extension being used.
The capture engine uses a value of 0xdeaddead and the stack checker uses
a different more complex pattern. I do not mind what is used so if you
have a preference for any reason please say.
Comments ?
Regards
  Chris Johns
