experimental networking drivers for amd pcnet / 79c973 (PCI) and intel eepro 10 / i82595 (ISA) available
Till Straumann
strauman at slac.stanford.edu
Wed May 4 16:27:31 UTC 2005
Joel Sherrill wrote:
> Till Straumann wrote:
>> Hi - FYI:
>> I ported the freebsd 'pcn' and 'ex' drivers to RTEMS
>> - 'ex' supports the (quite old) intel 'eepro 10' / i82595 chip.
>> Board-level support only for pc586 BSP and ISA cards
>> implemented.
>> - 'pcn' supports the AMD 'pcnet' chip based PCI cards
>> (79c973 + similar). I fixed endianness issues and made
>> it work on powerpc ('shared' + derived BSPs). Should
>> also work on pc586 [maybe with minor mods to accommodate
>> for differences in PCI and IRQ APIs].
> FYI Jennifer has been working to increase the commonality between the
> PPC, x86, and ARM "new" exception model implementations. She is
> also tidying up the bits I let on the PCI API unification. So getting
> this in the CVS tree is important.
> Till can we get them into the main tree?
Sure - I can post the stuff but unfortunately I can't do the integration
myself. My available time is dramatically below zero.
T.
>> - I had begun porting 'lnc' but then realized that 'pcn' was
>> what I wanted. I abandoned 'lnc' due to address space
>> restrictions. If someone needs to support the original
>> 'lance' chip - I have at least something to get you started...
> I recall seeing the Lance on a lot of older boards but for the life of
> me, I don't remember one of them. :)
>> HTH
>> -- Till
