Joel Sherrill <joel at OARcorp.com> wrote: > > But if the socket is closed, then shouldn't there be a path from the > blocking object going away which indicates an error occurred so > future references to freed resources can be avoided. > Yes. > Where in rtems_glue.c are you looking? See PR785. I have detailed the problem. -- Chris Johns
