Problems upgrading a BSP from RTEMS 4.5 to 4.6.2
Shadi T. Khasawneh skhasaw1 at binghamton.edu
Thu May 19 14:59:27 UTC 2005
> Shadi T. Khasawneh wrote:
>> Hello all,
>> Thanks in advance for any help and suggestions.
>> I'm working on a research project using the RTEMS 4.6.2 on a RAMiX PMC694
>> card. The BSP is working fine under the 4.5, but the RTEMS is not
compiling under the 4.6.2.
>> This is what I have done so far (Please let me know if there is a better
>> way do do it):
>> 1) Copied the old pmc694.cfg into make/custom, and modifed it to reflect
>> the new changes in 4.6.2 (based on some posts on this list).
>> 2) Added the pmc694.cfg into make/custom/Makefile.am
>> 3) Copied the pmc694 folder into c/src/lib/libbsp/powerpc/pmc694 3)
Modifed the bsp_specs in pmc694/ to reflect the changes.
>> 4) Created new Makefile.am and configure.ac files in pmc694/ and
Makefile.am files in the subfolders (the old version only had
>> Makefile.in
>> files).
>> 5) I have made a lot of changes/fixes to the Makefiles, and at the end I'm
>> stuck with the following error:
> There are a lot of tool differences between 4.5 and 4.6.2.  I assume you
upgraded tools.
> This would also be a nice BSP to be submitted against the CVS head.
I have installed the 4.6.2 version on a new machine, and copying the
pmc694 files from the old machine with 4.5.0.
RAMiX (which was bought by GE Fanuc) used to support RTEMS up to 4.5. They
stopped the support for RTEMS now. They support response was:
"The RTEMS development for the PMC694 went no further than version 4.5.0
of the OS. The BSP files that you have a link to is no different from the
last developed for the device. We have done no furhter development on the
driver."
They do support other RTOS's, but we would rather use RTEMS. That's why it
would be great if pmc694 can be included!
>> gmake[5]: Entering directory
>> `/shadi/rtems/bb/powerpc-rtems/c/pmc694/tests/samples/hello'
>> mkdir o-optimize
>> mkdir -p -- ../../../../../pmc694/tests
>> powerpc-rtems-gcc --pipe -B../../../../../lib/
>> -B../../../../../pmc694/lib/ -specs bsp_specs -qrtems
>> -DPACKAGE_NAME=\"rtems-c-src-tests-samples\"
>> -DPACKAGE_TARNAME=\"rtems-c-src-tests-samples\"
>> -DPACKAGE_VERSION=\"4.6.2\"
>> -DPACKAGE_STRING=\"rtems-c-src-tests-samples\
>> 4.6.2\" -DPACKAGE_BUGREPORT=\"rtems-bugs at rtems.com\"    -isystem
../../../../../pmc694/lib/include     -mcpu=603e
>> -DDONT_OFFLOAD_RX_CHECKSUM -DDONT_OFFLOAD_TX_CHECKSUM -Dppc603e  -O4
-fno-keep-inline-functions -g -Wall -ansi -fasm  -o o-optimize/init.o
-c
>> ../../../../../../../rtems-4.6.2/c/src/tests/samples/hello/init.c
>> -B../../../../../pmc694/lib/ -specs bsp_specs -qrtems    -mcpu=603e
>> -Wl,-Map,o-optimize/hello.map -o o-optimize/hello.elf o-optimize/init.o
../../../../../pmc694/lib/no-dpmem.rel
>> ../../../../../pmc694/lib/no-event.rel
>> ../../../../../pmc694/lib/no-msg.rel ../../../../../pmc694/lib/no-mp.rel
>> ../../../../../pmc694/lib/no-part.rel
>> ../../../../../pmc694/lib/no-signal.rel
>> ../../../../../pmc694/lib/no-timer.rel
>> ../../../../../pmc694/lib/no-rtmon.rel
>> /opt/rtems-4.6/lib/gcc-lib/powerpc-rtems/3.2.3/../../../../powerpc-rtems/bin/ld:
warning: no memory region specified for section `.eh_frame'
> missing section in linkcmds.
The same linkcmds file (startup/linkcmds) was copied from the working 4.5
version.
>> ../../../../../pmc694/lib/librtemsbsp.a(bootcard.o): In function
`boot_card':
>> /shadi/rtems/bb/powerpc-rtems/c/pmc694/lib/libbsp/powerpc/pmc694/startup/../../../../../../../../../rtems-4.6.2/c/src/lib/libbsp/powerpc/pmc694/startup/bootcard.c:128:
undefined reference to `main'
>> ../../../../../pmc694/lib/librtemsbsp.a(Hwr_init.o): In function
`init_BAT':
>> /shadi/rtems/bb/powerpc-rtems/c/pmc694/lib/libbsp/powerpc/pmc694/startup/../../../../../../../../../rtems-4.6.2/c/src/lib/libbsp/powerpc/pmc694/startup/Hwr_init.c:149:
undefined reference to `rxPciConfWrite'
>> /shadi/rtems/bb/powerpc-rtems/c/pmc694/lib/libbsp/powerpc/pmc694/startup/../../../../../../../../../rtems-4.6.2/c/src/lib/libbsp/powerpc/pmc694/startup/Hwr_init.c:151:
>> /shadi/rtems/bb/powerpc-rtems/c/pmc694/lib/libbsp/powerpc/pmc694/startup/../../../../../../../../../rtems-4.6.2/c/src/lib/libbsp/powerpc/pmc694/startup/Hwr_init.c:159:
> These are not in RTEMS AFAIK so I suspect you are not managing to link
against both librtemscpu and librtemsbsp
I have already changed it in bsp_specs, is that correct?
*lib:
%{!qrtems: %(old_lib)} %{qrtems: --start-group -lc -lgcc -lrtemsbsp
-lrtemscpu --end-group}
>> ../../../../../pmc694/lib/librtemscpu.a(exinit.o): In function
>> `rtems_initialize_executive_early':
>> /shadi/rtems/bb/powerpc-rtems/c/pmc694/exec/sapi/../../../../../../rtems-4.6.2/cpukit/sapi/src/exinit.c:151:
undefined reference to `_CPU_Initialize'
>> `rtems_shutdown_executive':
>> /shadi/rtems/bb/powerpc-rtems/c/pmc694/exec/sapi/../../../../pmc694/lib/include/rtems/score/thread.inl:32:
undefined reference to `_CPU_Context_switch'
> Hmmmm... double check your BSP configuratin and Makefile's against a BSP
using the same exception model.  This indicates you are missing
> getting the code in either libbsp/powerpc/support/... .  And I warn you
now that "old exception processing" is gone for all PowerPC CPUs except
4xx on the CVS head.
1) In pmc694/Makefile.am (already added the excpetion tag - NOT in 4.5)
SUBDIRS = .... @exceptions@ wrapup
2) in pmc694/configure.ac (RTEMS_PPC_EXCEPTIONS([old]) (already added)
3) In pmc694/wrapup/Makefile (as in score603e/wrapup/Makefile.am)
I have added ../@exceptions@/$(ARCH)/*.rel to the end of OBJ
(I did NOT add this before)
4) Executed bootstrap & compiled!
There error now (after making this changes & other changes mentioned
elsewhere):
-DPACKAGE_VERSION=\"4.6.2\" -DPACKAGE_STRING=\"rtems-c-src-tests-samples\
-D_OLD_EXCEPTIONS  -O4 -fno-keep-inline-functions -g -Wall -ansi -fasm  -o
o-optimize/init.o -c
../../../../../pmc694/lib/no-event.rel: In function `s.got':
no-event.c(*ABS*+0x100064): multiple definition of `_etext'
no-event.c(*ABS*+0x100064): multiple definition of `_edata'
../../../../../pmc694/lib/no-event.rel: In function `_end':
no-event.c(*ABS*+0x108068): multiple definition of `_end'
no-event.c(*ABS*+0x100064): multiple definition of `s.got'
../../../../../pmc694/lib/no-msg.rel: In function `s.got':
no-msg.c(*ABS*+0x100214): multiple definition of `_etext'
no-msg.c(*ABS*+0x100214): multiple definition of `_edata'
../../../../../pmc694/lib/no-msg.rel: In function `_end':
no-msg.c(*ABS*+0x108218): multiple definition of `_end'
no-msg.c(*ABS*+0x100214): multiple definition of `s.got'
../../../../../pmc694/lib/no-mp.rel: In function `s.got':
no-mp.c(*ABS*+0x100000): multiple definition of `_etext'
no-mp.c(*ABS*+0x100000): multiple definition of `_edata'
../../../../../pmc694/lib/no-mp.rel: In function `_end':
no-mp.c(*ABS*+0x108008): multiple definition of `_end'
no-mp.c(*ABS*+0x100000): multiple definition of `s.got'
../../../../../pmc694/lib/no-signal.rel: In function `s.got':
no-signal.c(*ABS*+0x100064): multiple definition of `_etext'
no-signal.c(*ABS*+0x100064): multiple definition of `_edata'
../../../../../pmc694/lib/no-signal.rel: In function `_end':
no-signal.c(*ABS*+0x108068): multiple definition of `_end'
no-signal.c(*ABS*+0x100064): multiple definition of `s.got'
../../../../../pmc694/lib/no-timer.rel: In function `s.got':
no-timer.c(*ABS*+0x100154): multiple definition of `_etext'
no-timer.c(*ABS*+0x100154): multiple definition of `_edata'
../../../../../pmc694/lib/no-timer.rel: In function `_end':
no-timer.c(*ABS*+0x108158): multiple definition of `_end'
no-timer.c(*ABS*+0x100154): multiple definition of `s.got'
../../../../../pmc694/lib/no-rtmon.rel: In function `s.got':
no-rtmon.c(*ABS*+0x100150): multiple definition of `_etext'
no-rtmon.c(*ABS*+0x100150): multiple definition of `_edata'
../../../../../pmc694/lib/no-rtmon.rel: In function `_end':
no-rtmon.c(*ABS*+0x108150): multiple definition of `_end'
no-rtmon.c(*ABS*+0x100150): multiple definition of `s.got'
../../../../../pmc694/lib/librtemsbsp.a(bcopy.o): In function `strlen':
bcopy.o(.text+0x94): multiple definition of `strlen'
/opt/rtems-4.6/lib/gcc-lib/powerpc-rtems/3.2.3/../../../../powerpc-rtems/lib/m603e/roe/libc.a(strlen.o):/home/rtems/src/packages/BUILD/rtems-4.6-powerpc-rtems-gcc-newlib-gcc3.2.3newlib1.11.0/build/powerpc-rtems/m603e/roe/newlib/libc/string/../../../../../../../gcc-3.2.3/newlib/libc/string/strlen.c:71:
first defined here
../../../../../pmc694/lib/librtemsbsp.a(bcopy.o): In function `memset':
bcopy.o(.text+0xac): multiple definition of `memset'
/opt/rtems-4.6/lib/gcc-lib/powerpc-rtems/3.2.3/../../../../powerpc-rtems/lib/m603e/roe/libc.a(memset.o):/home/rtems/src/packages/BUILD/rtems-4.6-powerpc-rtems-gcc-newlib-gcc3.2.3newlib1.11.0/build/powerpc-rtems/m603e/roe/newlib/libc/string/../../../../../../../gcc-3.2.3/newlib/libc/string/memset.c:65:
first defined here
../../../../../pmc694/lib/librtemsbsp.a(bcopy.o): In function `memmove':
bcopy.o(.text+0x118): multiple definition of `memmove'
/opt/rtems-4.6/lib/gcc-lib/powerpc-rtems/3.2.3/../../../../powerpc-rtems/lib/m603e/roe/libc.a(memmove.o):/home/rtems/src/packages/BUILD/rtems-4.6-powerpc-rtems-gcc-newlib-gcc3.2.3newlib1.11.0/build/powerpc-rtems/m603e/roe/newlib/libc/string/../../../../../../../gcc-3.2.3/newlib/libc/string/memmove.c:93:
first defined here
../../../../../pmc694/lib/librtemsbsp.a(rtems-cpu.rel): In function `s.got':
<built-in>(*ABS*+0x1009bc): multiple definition of `_etext'
../../../../../pmc694/lib/librtemsbsp.a(rtems-cpu.rel): In function `_edata':
<built-in>(*ABS*+0x1009c4): multiple definition of `_edata'
../../../../../pmc694/lib/librtemsbsp.a(rtems-cpu.rel): In function `_end':
<built-in>(*ABS*+0x1089c8): multiple definition of `_end'
<built-in>(*ABS*+0x1009bc): multiple definition of `s.got'
../../../../../pmc694/lib/librtemsbsp.a(bootcard.o): In function `boot_card':
../../../../../pmc694/lib/librtemsbsp.a(Hwr_init.o): In function `init_BAT':
../../../../../pmc694/lib/librtemscpu.a(threadhandler.o): In function
`_Thread_Handler':
/shadi/rtems/bb/powerpc-rtems/c/pmc694/exec/score/../../../../../../rtems-4.6.2/cpukit/score/src/threadhandler.c:112:
undefined reference to `_init'
/shadi/rtems/bb/powerpc-rtems/c/pmc694/exec/score/../../../../../../rtems-4.6.2/cpukit/score/src/threadhandler.c:113:
collect2: ld returned 1 exit status
gmake[5]: *** [o-optimize/hello.exe] Error 1
gmake[5]: Leaving directory
gmake[4]: *** [all-recursive] Error 1
gmake[4]: Leaving directory
`/shadi/rtems/bb/powerpc-rtems/c/pmc694/tests/samples'
gmake[3]: *** [all-recursive] Error 1
gmake[3]: Leaving directory `/shadi/rtems/bb/powerpc-rtems/c/pmc694/tests'
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory `/shadi/rtems/bb/powerpc-rtems/c/pmc694'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/shadi/rtems/bb/powerpc-rtems/c'
gmake: *** [all-recursive] Error 1
>> ../../../../../pmc694/lib/librtemscpu.a(interr.o): In function
>> `_Internal_error_Occurred':
>> /shadi/rtems/bb/powerpc-rtems/c/pmc694/exec/score/../../../../../../rtems-4.6.2/cpukit/score/src/interr.c:57:
undefined reference to `_BSP_Fatal_error'
>> ../../../../../pmc694/lib/librtemscpu.a(intrcatch.o): In function
`rtems_interrupt_catch':
>> /shadi/rtems/bb/powerpc-rtems/c/pmc694/exec/rtems/../../../../../../rtems-4.6.2/cpukit/rtems/src/intrcatch.c:51:
undefined reference to `BSP_panic'
> More PowerPC shared code you are missing.
`_Thread_Handler':
> Doesn't look like you have .init/.fini sections of the rtems_crti/crtn
code included
It seems that the rtems_crti was added only in the new version. Among all
the BSP's, it seems that motorola_powerpc is the only one using it (in
start/Makefile.am. But the files are in powerpc/shared/start/
How can I know that the pmc694 needs it?
=> bsp_specs (modified file):
>> %rename lib old_lib
>> %rename endfile old_endfile
>> %rename startfile old_startfile
>> %rename link old_link
>> *lib:
>> %{!qrtems: %(old_lib)} %{!nostdlib: %{qrtems: --start-group \
>> %{!qrtems_debug: -lrtemsbsp -lrtemscpu} %{qrtems_debug: -lrtemsbsp_g
-lrtemscpu_g} \
>> -lc -lgcc --end-group \
>> %{!qnolinkcmds: -T linkcmds%s}}}
>> *startfile:
>> %{!qrtems: %(old_startfile)} %{!nostdlib: %{qrtems:  ecrti%O%s \
%{!qrtems_debug: start.o%s} \
>> %{qrtems_debug: start_g.o%s}}}
>> *endfile:
>> %{!qrtems: %(old_endfile)} %{qrtems: ecrtn%O%s}
>> *link:
>> %{!qrtems: %(old_link)} %{qrtems: -Qy -dp -Bstatic -e _start -u
__vectors}
=> pmc694.cfg (modified file)
>> #  Config file for a MPC8240 based RAMiX PMC694 intelligent ethernet
card.
>> #  $Id: pmc694.cfg,v 1.1 2002/02/11 10:09:21 johnc Exp $
>> RTEMS_CPU=powerpc
>> RTEMS_CPU_MODEL=ppc603e
>> #PROJECT_TOOLS=$(PROJECT_ROOT)/c/build-tools/scripts
>> # This is the actual bsp directory used during the build process.
RTEMS_BSP_FAMILY=pmc694
>> RTEMS_BSP=pmc694
>> include $(RTEMS_ROOT)/make/custom/default.cfg
>> # We can use DEFINES to enable debugging macros
>> DEFINES = # -DDEBUG_INCR
>> #  This section makes the target dependent options file.
>> #  NDEBUG (C library)
>> #     if defined asserts do not generate code.  This is commonly used #
    as a command line option.
>> #  RTEMS_TEST_NO_PAUSE (RTEMS tests)
>> #     do not pause between screens of output in the rtems tests # #
STACK_CHECKER_ON (RTEMS support code)
>> #     If defined, stack bounds checking is enabled.
>> #  STACK_CHECKER_REPORT_USAGE (RTEMS support code)
>> #     If this and STACK_CHECKER_ON are defined, then a report on stack
usage
>> #     per task is printed when the program exits.
>> #  RTEMS_DEBUG (RTEMS)
>> #     If defined, debug checks in RTEMS and support library code are
enabled.
>> #  CONSOLE_USE_INTERRUPTS (pmc694_bsp)
>> #     The pmc694 console driver has the structure to operate in either
#     polled or interrupt mode.  However both modes only trap to the #
   monitor currently.
>> #  PPC_USE_DATA_CACHE (RTEMS PowerPC port)
>> #     If defined, then the PowerPC specific code in RTEMS will use #
 data cache instructions to optimize the context switch code. #
This code can conflict with debuggers or emulators.
>> #  PPC_VECTOR_FILE_BASE (ppc)
>> #     This defines the base address of the exception table.
>> #     NOTE: Vectors are actually at 0xFFF00000 but file starts at
offset
>> 0x0100
>> #  PPC_ABI (ppc)
>> #     This defines the calling convention (Application Binary
Interface)
>> #     used in this configuration.  EABI is the only one supported. # #
PPC_ASM (ppc)
>> #     This defines the assembly language format used in this
>> configuration.
>> #     ELF is the only one supported.
>> #  PPC_USE_SPRG (RTEMS PowerPC port)
>> #     If defined, then the PowerPC specific code in RTEMS will use some
#     of the special purpose registers to slightly optimize interrupt
   response time.  The use of these registers can conflict with #
other tools like debuggers.
>> define make-target-options
>>         @echo "/* #define NDEBUG 1 */ "
>>         @echo "#define RTEMS_TEST_NO_PAUSE 1"
>>         @echo "/* #define STACK_CHECKER_ON  1 */"
>>         @echo "/* #define STACK_CHECKER_REPORT_USAGE  1 */"
>>         @echo "/* #define RTEMS_DEBUG  1 */"
>>         @echo "#define CONSOLE_USE_INTERRUPTS 4"
>>         @echo "#define INITIALIZE_COM_PORTS 1"
>>         @echo "#define PPC_USE_DATA_CACHE 0"
>>         @echo "#define PPC_VECTOR_FILE_BASE 0x0100"
>>         @echo "#define PPC_ABI PPC_ABI_EABI"
>>         @echo "#define PPC_ASM PPC_ASM_ELF"
>>         @echo "#define PPC_USE_SPRG  0"
>> endef
>> #  This contains the compiler options necessary to select the CPU model
#  and (hopefully) optimize for it.
>> # Modified by Shailesh to disable DMA Copying..
>> CPU_CFLAGS = -mcpu=603e \
>> #CPU_CFLAGS = -mcpu=603 \
>> #                       -DDONT_OFFLOAD_RX_CHECKSUM
>> -DDONT_OFFLOAD_TX_CHECKSUM \
>> #                       -DNO_USERSPACE_COPY
>> # optimize flag: typically -0, could use -O4 or -fast
>> # -O4 is ok for RTEMS
>> # NOTE: some level of -O may be actually required by inline assembler
CFLAGS_OPTIMIZE_V=-O4 -fno-keep-inline-functions
>> # CFLAGS_OPTIMIZE_V=-O0
>> # This target does not support the ka9q tcp/ip stack so ignore requests
# to enable it.
>> HAS_NETWORKING=yes
>> # The following is a linkcmds file which will work without using the #
-specs system in gcc 2.8.
>> #       $(LD) $(XLDFLAGS) -T $(LINKCMDS) \
>> #         -o $@ -u atexit -u __vectors -u download_entry $(LINK_FILES)
#       $(LD) $(XLDFLAGS) -Ttext 0x20000 \
#ifeq ($(RTEMS_USE_GCC272),yes)
>> #define make-exe
>> #       @echo gcc 2.7.2 style linking not supported by score603e #
 @exit 1
>> #endef
>> #else
>> define make-exe
>>         $(CC) $(CPPFLAGS) $(CFLAGS) -Wl,-Map,$(basename $@).map \ -o
$(basename $@).elf $(LINK_OBJS) $(LINK_LIBS)
>>         $(NM) -g -n $(basename $@).elf > $(basename $@).num
>>         $(SIZE) $(basename $@).elf
>>         $(OBJCOPY) -O binary $(basename $@).elf $(basename $@).bin sed
-e 's/.$$//' $(basename $@).bin | \
>>           $(PACKHEX) >$(basename $@).exe
>>         #rm -f $(basename $@).s1
>>         rm -f *.o
>> endef
>> #define make-exe
>> #        ar x $(PROJECT_ROOT)/$(RTEMS_BSP_FAMILY)/lib/libbsp.a
>> #        $(LD) -u _sbrk $(LDFLAGS) -Map $(basename $@).map -N -T
$(LINKCMDS) -o $(basename $@).exe \
>> #             $(START_FILE) $(LINK_OBJS) --start-group $(LINK_LIBS)
--end-group
>> #        $(NM) -g -n $(basename $@).exe > $(basename $@).num
>> #        $(LD) -u _sbrk $(LDFLAGS) -oformat binary -N -T $(LINKCMDS) -o
$(basename $@).bin \
--end-group
>> #        $(SIZE) $(basename $@).exe
>> #        rm -f *.o
>> #endef
>> #endif
>> # Miscellaneous additions go here
>> # No start file
>> START_BASE=
>> DRIVER_ARCHITECTURE=
>> Thanks,
>> Shadi
>> ______________________________________
>> Shadi T. Khasawneh
>> Graduate Research Associate/Endicott Interconnect Technologies
>> Department of Computer Science
>> State University of New York at Binghamton
>> P.O. Box 6000
>> Binghamton, New York 13902-6000
>> E-mail: skhasaw1 at binghamton.edu
> Joel Sherrill, Ph.D.             Director of Research & Development
>     Support Available             (256) 722-9985
Shadi T. Khasawneh
P.O. Box 6000
