Scanf is not working in posix sample
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Mon May 23 17:12:34 UTC 2005
Jason Davis wrote:
> Hi Joel,
> It looks like you a right. I found the same issue in the mailing list of
> Sep2001. Your answer was to configure the clock tick driver. Is there an
> example availble on
> the net, that shows how to do this? This would be helpful for newbies.
It should be as adding
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
below the line that does the same for the console driver.
See ticker in the sample tests for an example.
> Thanks
> Jason
> -----Original Message-----
> From: Joel Sherrill <joel at OARcorp.com> [mailto:joel.sherrill at OARcorp.com]
> Sent: Monday, May 23, 2005 12:29 AM
> To: Jason Davis
> Cc: rtems-users at rtems.com
> Subject: Re: Scanf is not working in posix sample
> Jason Davis wrote:
>>Hello,
>>I modified a posix printf example slightly with an additional scanf.
>>But I can't figure out why the program is not running. It starts and
>>shows the printf "Hello World" string but the it stops without any
>>possible input via keyboard. I'm using a PC board with a PIII.
>>I added the test.c file and my makefile below. Any ideas?
> Is there any chance the keyboard is polled and you need to enable the clock
> tick driver?
> --joel
>>Regards,
>>Jason
>>The test.c file:
>> * Simple test program -- simplified version of sample test hello.
>>#include <bsp.h>
>>#include <stdlib.h>
>>#include <stdio.h>
>>#include <stdlib.h>
>>void *POSIX_Init(
>> void *argument
>> int nummer;
>> printf( "\n\n*** HELLO WORLD TEST ***\n" );
>> printf( "Hello World\n" );
>> scanf("Eingabe: %d",&nummer);
>> printf( "*** END OF HELLO WORLD TEST ***\n" );
>> exit( 0 );
>>/* configuration information */
>>#define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
>>#define CONFIGURE_POSIX_INIT_THREAD_TABLE
>>#define CONFIGURE_MAXIMUM_POSIX_THREADS 2
>>#define CONFIGURE_INIT
>>#include <confdefs.h>
>>/* end of file */
>>And my makefile:
>># Makefile
>># RTEMS_MAKEFILE_PATH is typically set in an environment variable #
>>EXEC=hello.exe
>>PGM=${ARCH}/$(EXEC)
>># optional managers required
>>MANAGERS=io
>># C source names
>>CSRCS = test.c
>>COBJS_ = $(CSRCS:.c=.o)
>>COBJS = $(COBJS_:%=${ARCH}/%)
>># C++ source names
>>CXXSRCS =
>>CXXOBJS_ = $(CXXSRCS:.cc=.o)
>>CXXOBJS = $(CXXOBJS_:%=${ARCH}/%)
>># AS source names
>>ASSRCS =
>>ASOBJS_ = $(ASSRCS:.s=.o)
>>ASOBJS = $(ASOBJS_:%=${ARCH}/%)
>># Libraries
>>LIBS = -lrtemsall -lc
>>include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
>>include $(RTEMS_CUSTOM)
>>include $(PROJECT_ROOT)/make/leaf.cfg
>>OBJS= $(COBJS) $(CXXOBJS) $(ASOBJS)
>>all: ${ARCH} $(PGM)
>>$(PGM): $(OBJS)
>> $(make-exe)
>>j:
>> @echo $(CFLAGS_DEBUG_V)
>> @echo $(RTEMS_USE_GCC272)
joel at OARcorp.com On-Line Applications Research
