Allowed system calls in ISRs
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Fri May 27 13:23:01 UTC 2005
Ingolf Steinbach wrote:
> Hi,
> section 6.3 of the RTEMS C users' guide lists system calls that
> may be made from ISRs. Apparently this list is incomplete:
> "Interrupt Manager" is missing completely while section 6.4.5
> suggests that at least rtems_interrupt_is_in_progress() is
> allowed in ISRs.
> I'm specifically interested in rtems_interrupt_catch(): is
> it allowed to change an interrupt handler while in an ISR?
That should be OK. It doesn't allocate memory or block. Those
are the two biggest factors.
> Kind regards
> Ingolf
joel at OARcorp.com On-Line Applications Research
